Air pressure front forks Cube Kathmandu
ladymelchet
19
Hi I have a new Cube Kathmandu Pro. Would be grateful if somebody could tell what the air pressure should be in the front forks please in PSI or Bar measurement. The bike use for leisure riding on roads/tracks only. Many thanks
8,230
The forks should sag about 15/20% of the travel with you on the bike, so setting a PSI isn't universal as every one weighs differently.
AndyBike
1,173
514
My mistake. I thought it was a sunpoor fork. But the answers pretty much the same. In your manual for the fork it will give air pressures which depend on your body weight.
If you didnt get a specific manual, and only a general bike one, you can get it online by simply googling X-fusion Mig32 manual.
As i messed up earlier, here it is to save you time.
You will need a high pressure pump
Such as this.-
The maximum air pressure for that fork is 150psi. You should NEVER exceed that or it will go bang and knacker the fork totally.The info is all there, just double check and dont overdo it.
