My other bikes have the pedelec combined with the throttle IE if I`m pedaling and open the throttle the throttle takes control which has in my case been good because opening the throttle gives me just a touch more power which normally sees me over the hill etc. On the aurora there is a switch by the R/H grip (just below) where your thumb rests and this switches between pedelec only or throttle only. Now that is opposite to what I`m used to and was initially a disappointment. After riding the bike for the first time in earnest I began to see the wisdom of the set up. When I set off I use throttle to get me moving while I slip my foot into my strapless clips and as the foot goes in I flick the switch over to pedelec normally with the power setting set to either low, med or high depending on the terrain or my mood for riding. When approaching a junction or corner I usually switch back to throttle for complete control unless I can clearly see that the road(or track) is clear when I`ll just pedal out making allowance for the power the bike has. (BTW the latest Alien road legal kit works the same way)What mode do you end up mainly using with the alien bikes, throttle or pedelec. One other question, the aurora has the two modes but can you mix them, as i noticed someone said they used the throttle to control the power in pedelec mode. I thought it was one or the other.
What are the assist powers, i am mainly interested in pedelec mode as i do want to get a lot fitter but some of the hills in my area are severe and rule out sensible commuting on a normal bike. If i go round the hills it adds another 4 miles on and things just start to get ridiculous. The e-bike is the perfect solution, thats why i am tending towards the aurora as its advertised as a hill climber and thats the whole problem on my route. I plan on cycling 85-90% of the way on low assist but on the hills all the help possible so i arrive at work in reasonable condition
I`m fussy at the way things work( believe me) and I have no problems using the controls for the bike to do just what I want it to do.(once you get to know it) I make no excuses(or should I say Alien makes no excuses) for the amount of power the bike has. The way I see it, you either want/need a powerful bike or you don`t, if you want the extra hill climbing power (top gear hill climbing if need be) then you have to be prepared to tame the brute at times. For instance approaching a particular spot on route where I know the sand is thick I flick to throttle in a fraction of a second and gain complete control. If I approach a bend on a steep path that I know where it`s good under foot then I just coast in and pedal out and avoid any loss of speed or power, it`s great.
Don`t get me wrong, it`s not an uncontrollerble monster but you do have to just be aware for the first few miles that it could bite you a touch harder than the average but of course you now have the knowledge that I didn`t have
