Alternative battery charger
wehey
117
7
52
Hiya all.
The charger i have with my 48v battery has a built in fan to keep it cool. The problem is that it doesn't allow for stealthy charging at work as its really noisy.
Is there an alternative available without a built in fan?
The spec of the battery are as follows
48V Capacity: 10.4Ah(25℃) over-discharge protection.
Size 34 x 12 x 8 cms
Weight 4.3±0.05kg
Standard discharge 10±0.5A
Maximum continuous discharge current 25±0.5A Discharge cut-off voltage ≥ 42V
Battery over-discharge protection
Charge voltage : 54.6±0.2V
Charge with matched charger
Standard charge 2±0.5 AResistance ≤150mΩ Between discharge port of positive and negative
Thanks in advance :)
KirstinS
3,224
899
Brighton
Hi there
Yes, looks like standard issue 48v lithium charger to me from those numbers
can you post some pictures of the battery connector plug please ?
thanks
Kirstin
wehey
117
7
52
Hi there
thanks
Kirstin
Here ya go. Sorry about the poor quality
KirstinS
3,224
899
Brighton
The charger d8veh pointed out has three options for a connector but not that one
Good news is it's very standard - you can pick one up from maplins, cut the wrong connector off and solder the right one on
