anyone had success with holts or simular tyre repair for there bicycled got fed up carring tubes
footpump
713
75
76
hi all quite a while ago purchased some poundland innertube repair stuff in pressuried can as I often got punctures on canal towpaths and thought this might save the hassle of repairing or fitting new tube until i8 got home.
got a puncture 700x28cc tube and found there was not enough pressure in the can to force the repair fluid into the tyre, had to go to nearby pup and borrow some spoons to fit the spare tube I had with me.
with my ebike its m+ and slime.
but have often wondered if anyones used the holts car tyre repair stuff on there ebike or bicycle with any succees £3.50 in wiilco for small medium car tyres
6,729
Reactions: Andrew Ford
Bigdaddyuk666
155
50
39
Leicestershire
I'm considering it myself good price too but I'm skint till the end of the month as just put deposit on a paintball party I've planned for the lads at work
Sent from my SM-G925F using Tapatalk
... My suggestion is to buy slime filled tubes at Halfords , They have an own brand tube at about a third price of the top brand. If you have the option I would recommend using the car valve type, rather than the presta type.
Andrew Ford
84
37
54
Rotherham
Sound wave
I know you answered one of my previous post, thanks
Will the kit convert normal rims and tyres to tubeless with out any problems
Would I have to buy new tyres?.
Andy
6,729
it will depend how tight a fit the tyre is on the rim if it is a tight fit then it should seal up just you wont be able to run lower psi in the tyre.
if it is a lose fit then you might get problems getting it to seal and end up using a lot more sealant to do the job.
even if the tyre is tl ready they still can be a pita to get on it just depends on the tyre and rim.
tho if you use more rim tape that will make the tyre a tighter fit and get more chance of a seal.
if you have a valve take the tube out and see if you can get the tyre up ;)
footpump
713
75
76
2 of my ebikes have puncture resistant tyres +slime tubes or filled with slime 700c and 26mtb my subway however is 27.5 changen a tube yesterday small thorn in tyre 1500 miles covered prior to puncture.
decathlon do slime type tubes £3.99 but did not have 27.5 in shop
or £2 for normal I add half bottle of slime.
having seen the holts tyre sealant today just wondered if its worth carring one for longer journeys just in case of a mishap?
ill see what Halfords own brands have in stock
6,729
they use staple guns at the hospital ;)
footpump
713
75
76
went to Halfords no own brand 27.5 there, went on to decathlon to find the store has shut down back to Halfords for non slime 27.5
