bad batt.
lessped
170
Oh dear it would seem my batt. has given up the ghost only had the bike since last sept. couldent ride it cos the weather was very inclement so kept charging the batt. every 2-3 weeks for the last 6 or so months and now it wont hold a charge for more than 10 mins it would seem i will have to pay out another £280 for a new one having only ridden less than10 miles (groan)
lessped
170
What make of bike is it lessped?
Hi Flecc my bike is an Alien special i am well pleased with it but it seems i may have let the battery get to low even haveing charged it on a regular basis just my luck .
30,810
Alien did have a bad batch of batteries some while ago and Bob there changed the faulty ones promptly. I think you should get in touch with him since you have obviously been charging regularly. Not being used doen't hurt these batteries just so long as they are charged, as you've been doing.
From last September the battery is only six months old and hardly used, so claiming is definitely justified.
lessped
170
Flecc thanks for your promt reply and yes i have been in touch with Jim at ALIEN he has asked me to send it back so they can take a look once again thanks for the info. your a star ;) p.s. will keep you and the forum up to date .
30,810
I'm glad they are having a look at it, hopefully they'll replace it for you.
lessped
170
Hi again just a thought but there might be another little spanner to throw in to the works i.e charger, after using the bike before christmas of last year i duly topped it up at regular intervals and then as i said every two to three weeks untill the present day but i did notice thinking back on it now , that each charge took about the same amount of time but as i was just topping up from short rides i thought nothing of it so i may have another suspect in the equation .....never rains but it pours !
30,810
Not necessarily. The BMS in the battery uses some current all the time it's out of use, so the charge drains continuously. Therefore the charger must make up for that as well as any used on short rides.
So don't worry abut the charger, it's almost certain to be ok. Even a faulty charger won't harm a lithium battery, it's the battery's internal BMS that switches off charge when the battery is full, regardless of the charger.
lessped
170
Once again i am in your dept Flecc thanks for easing the pain a little :) oh by the by one more question is that right that one of these lithium batts. will lose approx. 5% per week ?
30,810
It could do, but that amount depends on the design of the individual BMS circuit in the battery. The lithium cells themselves lose no current, it's just the current used by the management circuit which is effectively switched on all the time.
The expensive but smart Panasonic unit battery switches off it's own BMS after two weeks of not being in use, but that's a bit of a luxury.
lessped
170
Understood thanks again Flecc ,oh for a bottomless pit of money ............ BMS ?
30,810
BMS = Battery Management System. It controls the charge and evens out the charge into the cells to ensure the battery is balanced. When the battery is full, it cuts off the charger input. Then the charger senses no current is being taken and indicates charge is finished.
lessped
170
Bad BATT. no GOOD BATT.
Hi all im back with the final saga of the bad batt. well i sent it back to Jim at Alien he duly tested it and came to the conclusion that it would not hold the charge but anyway it took about a week to sort it and finaly they sent me a replacment with no quibble so it was a happy ending after all once again thanks for your support and help Flecc cheers n beers :)
30,810
Glad it's sorted now and Alien came good once more. Hopefully many trouble free miles in prospect now. :)
