Bafang 750w
Wafty Cranker
17
Hello again, I’m contemplating buying a Bafang 750w mid drive and believe the physical size is the same as the 250w motor which got me thinking what identification marks do they display to show which is which ? Can you see where I’m heading with this ? Thanks Wafty.
Deleted member 33385
My BBS01b motor has "36V 250W", faintly printed on along the bottom. Some people on this forum have mentioned 750W motors printed as 250W, but I have no idea who sells them.
6,697
id get the 1000w hd one and turn it up because they are all not road legal in the uk because you can change the power and speed settings with the data cable and some displays i think so classed as a off road switch.
you will only have a problem if you kill someone apart from that you wont have a problem the police wont chase you i over took a meat wagon the other day going 30mph on the pavement not interested!
Appeal to trace man who outran police on electric scooter
He has made off from police on 'multiple occasions.'
:p
Reactions: Wafty Cranker
:p
HOLY HELL!!! How has he hacked that?!?!?!? o_O
6,697
Reactions: pentiumofborg
Yep, my battery can't cope with the BBS01b sometimes on some inclines, so I keep it on PAS 8 rather than it's max of 9 - cuts out but doesn't burst into flames.
If you're ever in a survival situation and your phone has died - just stab the battery with a knife or bash it with a rock and cover it with some kindling... you'll soon have a fire.
6,697
you can make that in to a 18650 hand grenade as it has no short circuit protection on the pcb so if you put in 1 cell the wrong way round it will blow up all the cells in the pack.
tho you would need to reinforce the 4 springs as they melt so i guess it has a bit of protection lol they do a 6 cell one as well as used them for my old lights.
3,994
The 250w one is not the same size as the 750w one. The mountings and reduction system are the same, but the 750w one has a wider motor because it hs bigger windings with thicker wire. The two motors and controllers are interchangeable, so it's possible to have a motor officially marked 250w, but with the 750 motor and controller.
The high power 250w version is actually a differently stamped 500w one, which runs at 36v and 25 amps instead of the standard 36v and 15 amps of the 250w one that can be turned up to 18A in the software.
My BBS01b is set at 20A in software, I might turn that down to 18 because it occasionally struggles at max PAS 9 on some hills.
Wafty Cranker
17
Interesting that, bit if wet &dry and a waft over with a rattle can maybe. Thanks
Wafty Cranker
17
Thanks, l though they used same casing. Learning all the time !
3,994
Use Google to search for pictures of the narkings before you think that a bit of wet and dry and a rattle can will sort it.
8,740
The markings are etched in quite deeply, you will need a Dremel type tool to grind off any such marks and the surrounding ali casing.
