Bafang BBS01 Power Cable Connector
Aushiker
This is probably a long shot but I just wondering if anyone knows what the battery cable connectors used on the Bafang BBS are called or if you know of a source.
It is the plug at the bottom right in this bad photo. The connector is marked 8Fun.
Here is a slightly better photo from the battery end ...
They are a waterproof two pin style of connector that pushes together. I have found a very similar one at dx.com but it is a screw together type and comes with cable. I just need the connectors if I can find them easily.
Otherwise I will cut off the existing cable and use XT90 connectors but thought it worth a shot first.
Andrew
C
Cyclezee
Hi Andrew,
I think you meant the battery cable connector is bottom right as we look at the top photo.
Just wondering why you need another one?
Not very helpful, but I don't their name or where to source them, they may be unique to 8Fun, if not I'm sure someone on here will know.
amigafan2003
1,389
139
Yep aware of that ... linked to that in my opening post :)
Andrew
Sorry, my fault for just scanning.
My BBS02 didn't have that connection for the battery - just a couple of bullets. So I cut them off and fitted a pair of Anderson 45 connectors.
