Have now tried a little more for real. Trail riding some very great trails with lots of transporting also. Did I say it was a MTB? Basically it is better, but not perfect. Battery life is slightly decreased, but still very good. On my new display C963 there is a Watt-meter and I have kept my eyes a little on it now. It peaks about 450W and continuos power about 350W. Battery lasts 50% after a long ride, that is great. So I think I will let this be for now. Have attached final parameters here also.
Coming from a Bosch CX with eMTB mode I have high demands
but it is good now (I also have a front hub drive commuter bike). Two things I noticed compared to the Bosch CX, there are these two behaviour changes when I now use BBS:
1) Start pedalling before you usually would after a short interuption (this threads topic).
Just because the motor ramps up and you don't want to start from zero. If you, for example ride a slight uphill. Stops pedalling just short enough so that the motor stops, then start pedalling again. You loose speed because the assist is low. Before on stock settings it felt kind of hitting a wall. But even now after tweaking your flow is disturbed and that is slightly frustrating so to handle this one thing is to start pedalling just a little earlier (if you can do that in that moment of course).
Related is gear changing. Sometimes you really don't want it to cut power totally when changing gear, so you change gear in full assist basically. To make drivetrain a little happier you could try pedal very soft so that your own power doesn't add to motor power.
2) Use slightly higher gear than you use to.
Because the motor spins out quick. When I pedal with normal cadence (which is quite "high" because I come from road biking before). The motor stops to assist just when cadence is in sweet spot. So I often use slightly higher gear than I would do if was unassisted. And the RPM range is a little narrow. So on each gear I spin out just before changing gear.
That is adjustable though, I have the keep current setting on 60% (was 20% stock and that was terrible!). Guess it could be tweaked some more.
Related is top speed also. I have 10-46 cassette with 35T chainring and assist reaches about 31 km/h before it ceases. That with 700C tyres, would be interesting to calculate motor spindle speed if you cope
Ok, long rant but interesting observations I've done. Finally some last words about the Bafang BBS. No system is perfect. Bosch CX is very good but have some issues also that made me sell the thing and get Bafang instead. This system though is very impressive. It is high quality, easy to install and adjust. Silent, you almost don't hear it if it's not silent around you. Works very great but stock settings can need some tweaks to make it shine. And here we comes in to systems sweet spot. Although it is good as it is and for people just wanna slam it on and use it. It is very good for us that likes to tweak, there are many things you can buy and there are lots of information on the internet because it's popularity. Also the battery is standard, so you have tons of battery options as well. Very happy with my new bike and it feels now that I will keep it for long.
