For Sale Bargains
AndyBike
1,777
767
also rim brakes would probably be in the wrong place
Im sure theres some sort of adaptor available that raise or lower the brake mounts so you can use larger or smaller wheels on a standard fork.
This is from something i read on RetroBike yonks back. Probably to do with the industry's changing wheel size.
Make/model/part number i've no idea, but pretty sure something is out there.
2. It has no disc fixings, so rim-brake only, which is not good for an ebike.
My 26" Dahon Esperesso folder has rim brakes.
Hardly definitive, but i suppose in all fairness it depends on how fat a bloater you are and how fast you ride
4,241
It's not just about the energy that needs dissipating. You need modulation and control too, which are more important for a light rider.
4,241
15.2% slower. Oodles of hills around here.
You can always run it at 48v, which will increase its speed and torque by 30%, so next time I come out of the pub to chase you up the hill, you might be able to give me a run for my money.
Peter.Bridge
1,868
828
New front hub motor for £91.99 delivered, sold by the amazing BankruptBikeParts. UK based, discount code is shown below. Ten motors are available. Is this a bargain for a cheap build? Is this really a Bafang? What's a SWXB? For 36H 28" wheels, would it work ok with 26"? Does "Panterra" mean it's heavy metal? Must I get tattooed?
36V 250W PANTERRA SWXB BAFANG Front Electric Wheel Hub Motor 28” (700c) ED-3
https://www.ebay.co.uk/itm/203700362856
What's a Panterra ED-3? This:
Is this motor wound to be optimally efficient at 20mph?
You can get a built 26" front hub wheel kit (mxus xf07) with KT controller , display and pas sensor for £143 free shipping from Germany
4,241
That's a really good deal. Thanks for pointing it out. I looked at them before but couldn't find anything interesting and legal; however, I just found and ordered a MXUS XF08C rear cassette motor for only £69 inc shipping! It's a shame they can't do that motor in the above kit.
3,411
I've seen that listing before. It didn't and still doesn't state which controller is supplied, then I lost interest again. Does the 250W front motor kit have a 7A controller? That's 252W with my 36V battery. I'd have to throw the single figure rated controller away and buy a 20A controller, possibly with another LCD to ensure compatibility? Also, I have cable brakes:
"5.Wuxing Brand Brake Lever,Fits bafang oil Hydraulic Brake Sensor(Not included)"
What does it mean by "Not included"?
Alway something janky about PSWPower's bundles, or perhaps it's just this one.
63046
Peter.Bridge
1,868
828
Looks like they have the freewheel xf08 in stock but not the cassette xf08c
Peter.Bridge
1,868
828
Alway something janky about PSWPower's bundles...
7a rated 15a max, yeah that's standard, rated always seems to half maximum. 15a *36v will be fine for your svelte figure. I think 20a might be too much, Woosh supply there xf08c kits with 17a max controllers
Usually you get cable brakes levers with brake cut off but have to pay extra for hydraulic brakes sensors but I usually throw them away - don't need them with KT controller, just don't brake and pedal at the same time. I do have two bikes where I fitted hydraulic brakes sensors, they are very much ooptional
3,411
That 7a rated is 15a max is good to know, thanks. I I look svelte at the mo, but the hills around me won't be without billions of years of additional weathering, unless tectonic plates collide in my local area again. Where I live was once sea bed. Trilobites are everywhere. Hence the 20A controller requirement.
Peter.Bridge
1,868
828
I look thin at the mo, but the hills around me won't be without billions of years of weathering, unless tectonic plates collide in my local area again. Where I live was once sea bed. Hence the 20A controller requirement.
I can get up most of the hills near me with the Woosh XF08c kit and 17amp controller at a not so svelte 105kg. I do have to add some pedalling power though
Peter.Bridge
1,868
828
I think 20a might be too much with quite a few of the 250w rated hub motors, I've seen recommendations here for maximum 36v•18 amps to not strip nylon gears
3,411
Cheers, good to know.
I'm rather spoilt by the ease of zooming about effortlessly on my BBS01B, and you're losing me with this having to add pedalling power stuff. TBK do a 22A controller, seems like it has the right connectors for a MXUS PSWPower front motor, but I'd have to choose cable length, PAS. I'll look into it all, if I suddenly feel a sense of overriding enthusiasm for a harder to pedal hub conversion. Overriding enough to assemble the Dahon Espresso, which will take some overriding.
Yes I've read that, about the AKMs?
4,241
36v at 20A gives the same hill-climbing as 48v 15A. KT controllers are normally dual voltage. The picture you showed indicates 36v/48v dual voltage version.
4,241
Every one I tried could run with 22 amps at 36v. It's only when you go up to 48v that you need to be more careful. That XF08C I ordered is going to be run with 22A at 48v.
Somebody stripped the gears on one of the Suntour motors when running at 48v, but I'm not sure what the current was. The gears on them don't look as strong as this type of motor. Forum member Cwah also wore the teeth on a tiny high speed Q100 motor running at 20A and 48v.
Reactions: Peter.Bridge
4,241
3,411
For any 8 speederists out there.... At times, it can be difficult to source SRAM 11-32T 8 speed cassettes. Genuine most likely because they're being stocked by Amazon themseves, and £16.99 is a good price. I've ordered two.
https://www.amazon.co.uk/dp/B000NNX2P4
Reactions: Wayners
4,241
MXUS XF08C motor from PSWPower £69 inc motor cable, shipping and taxes.
Spokes from Amaxon £10:
Complete kit from PSWPower rady to fit.Just add a battery£186:
Rim Exal SL19 were £18 a pair from Ebay. I don't see any at the moment to provide a link.
Total cost of motor wheel £89. Add a KT controller set from PSWP for £40 gives a really good kit for £130. You can get a battery from PSWP too (48v 13Ah £120), but might be better from Yose of Greenlance, depending on which one you want.
63180
3,411
New wheels have never been perfectly true. I had bought a rear wheel from BanruptbikeParts on ebay months ago, and because I have rim brakes, I wanted to make certain it was perfectly true before installation, thought I'd try my local bike shop's wheel truing service - the 1000 year old owner held the axles in his hands and asked me to give it a spin... then said "Nothing much wrong with that. Not worth paying for. You'll be fine". Refused to inspect it further. Said he might if I returned and insisted, after having a good look at it myself.
...at that moment I resolved to buy a truing stand, trouble is the cheaper ones can't do 74mm axles without dodgy inaccurate (if I were making them) self-made adapters. Spotted this, ordered it. Is it a bragain? Is it crap? We'll see. It has dials. No VAT because it's shipped from the UK not China, £6 off with coupon code GBSS49Z6. £1.20 cheaper still with blue knobs, but I didn't notice. Other similar truing stands I've seen cost more. Hope it arrives and works, I've three wheels to build.
https://vi.aliexpress.com/item/1005008720749865.html
63182
4,241
Waste of money. Put the wheel in the bike and use two cable ties as pointers.
