For Sale Bargains
Waspy
640
262
I see the story has unfolded in my absence.. - was late/early - perhaps i was a bit grumpy and too short..
-fwiw in my case its a facebook login page, no window with an alt-f4 escape, perhaps you need an app or toolkit installed for the 'floating' login prompt??
This is what I get using Chrome on my Windows 11 laptop.
I guess all devices/browsers are different.
AndyBike
1,762
752
Nicely priced full susser here. £2800
It was never that rrp. The actual price originally was £4500, which is about right for this level, About a £1700 saving.
Downsides -
Fugly
Brakes could be a much better spec at this price range, Shimano m520 or maybe SLX or even XT
Wheels are mediocre, but will do what you need them to
Fugly
Overall, I'd say this is an excellent starting point for a good play/trail bike but don't want to be spending a fortune.
A few upgrades wouldn't hurt, namely the brakes but really thats about all. Fork is ideal Zeb(38mm) so it will pretty much handle anything.
Best ridden at night, or if wearing a disguise ;)
4,160
Interesting pricing. I don't think Winstanleys are selling that bike at £2800 bcause they feel sorry for us. I reckon it's because nobody wanted to buy it at £4500, and they figured that their only chance to get rid of it is to try it at £2800. In my mind, that's still at least £1000 too much for any ebike, when you consider what you can get with a petrol motor in it.
Reactions: Oldie
AndyBike
1,762
752
I really cant see how you arrive at the figure you have.
3,407
Cheers @guerney, TLDR- I dont carry a mobile phone . Thanks for the info regardless
I usually avoid mobile devices for browsing unless necessary - what browser are you using on what OS?
Wayners
506
106
56
Gloucester
Seems a good buy. Id want to message to ask about if tyre is included
3,407
That seller has a zero rating. Ask why it says "This product is a set of 3 silver motor sticker decals designed for E-Bikes, specifically compatible with Bafang 250w 36V BBS02B and BBS01 motors." for item description.
When I'm occasionally gripped by a fleeting irrational urge to muse about trying a hub conversion, I ask for exact make and model. I also ask if the motor has been marked "250W" by the manufacturer, and request photos of the markings.
Peter.Bridge
1,839
822
20" hub wheel kit from Yosepower £134 https://www.yosepower.co.uk/products/e-bike-conversion-kit-36v250w-20-front-motor
Add a 10Ah 36v battery £163
And a Intercity disc 8
And you've got quite a nice lightweight folding bike with a decent range for £500
Reactions: Waspy
Waspy
640
262
I clicked on that Marketplace link, the bike is hardly used and he's currently asking for £190. I saw this on the same page, it would be a good purchase for Soundwave:
egroover
1,101
656
58
UK
Aliexpress 20% cashback on every purchase today with Topcashback
4,160
If you look through my threads a few months ago, I gave some explanations on how to spoof the speed or pedal sensor signals with a cheap Aliexpress device. Today, I saw this video for another device. This one is much more suitable for testing. It could also be used as a permanent installation if you have somewhere to put it.
It runs off 5v, so you can use the pedal sensor, speed sensor or throttle power wires to power it, and send the output through the pedal sensor or speed sensor signal wires. For a permanent installation as a pedal sensor spoof, you'd need an accessible momentary switch on the 5v wire.
This one is very easy to set. For pedal assist spoof, the frequency would be one turn of the pedals per second, which would typically be 8 or 12 magnets per second, so say 10hz. Duty cycle would be 50%. For speed sensor spoof, there's normally only one magnet, and a 26" wheel turns at about 201 rpm at 15 mph, so 200hz would show as about 15 mph. The pedal sensor needs a discrete pulse, so duty cycle should be around 10% or less. Some controllers have the speed sensor pulse low rather than high, so if 10% doesn't work, try 90% or higher.
The ideal use for this device is to test your system if you suspect that the pedal sensor isn't working or is giving problems, though you will have to use an appropriate connector.
Reactions: thelarkbox
17,397
Don't you mean 201/60 Hz?
matthewslack
2,586
1,669
egroover
1,101
656
58
UK
Noticed this near me
With the recent high profile (check our socials) crackdown on throttle/illegal ebikes by most police forces (easy pickings, look at our crime rate figures), I'd take such joy throttle riding with my feet up on the crossbar past every rozzer I came across in town. Then pull out my regs doc showing bike is legal and witness the walk of shame !!
Note, I don't advocate the use of illegal ebikes on public roads, but I've never once heard the cops in this crackdown social media self congratulating videos mention that pre 2016 throttle bikes are excempt
4,160
I'm not sure if I understand you correctly, but in case you don't know, the police issued a bulletin sheet, which was a sort of flow chart of what they should check for. It had a decision point for independent throttle or not, then the independent throttle line branched into pre 2016 or not. You can find it in the "more seizures" thread.
Reactions: AntonyC
AntonyC
418
173
Surrey
Do you have a bit more of a lead on that police bulletin sheet? There are useful links to regs and checks but I'm not having much luck finding one by the police, which would be really useful to carry.
Reactions: POLLY
3,407
These £5.99 Aldi wire strippers are rather good. Adjustable, and they even work on thick ebike or 13A cables, if you make a light cut/score around the cable sheath first, before separation (no auto cut).
