Hi All
I thought I would post this .
I took this nearly new battery in a PX deal which someone damaged whilst trying to open.
They stabbed the cells whilst trying to open. They are difficult to open as now glued and screwed in the factory .
I will be taking it too a battery company in London but before I do I would like to just have a bit more knowledge of the battery .
It’s from a late Carrera
I plan to have the damaged cells replaced and have a standard BMS fitted.
I may have some if they are the same cells as the last one I tried to repair but damaged through lack of experience and knowledge
I intend take out the on and off switch on the top of the battery and repair the hole with two pac plastic filler and a little fiber glass on the inside.
Possibly fit a new on and off switch and fuses there is room in the case .
Change the jack to standard one that will fit my YOSE charger that is exactly the same voltage output ECT as the Phylion Carrera one that charges HL 36V batteries.
I intend to use this one for my test kit ie testing parts mainly Carrera Suntours that I sell on e bay so the Canbus communication is not needed or wanted
Some advise on a good quality safe BMS that will match this set up would be very help full before a]I take it to the battery company so I can then listen to their advise with an opinion.
I have been looking at what is available on from top bike for instance but not sure what is suitable
Brands to avoid would be helpful..
Cheers
Baz
Cheers
Baz
