Hi,
So I ordered a battery from ping the other day, somewhat in haste and after far too much wine to be thinking straight. Should have planned it all out a bit better really. Anyways the battery is 280mm x 105mm * 85mm. The idea was that if I wanted to put it on top of the rack it would still leave access to the sides to attach panniers.
It should also be possible, maybe, to attach it to the downtube as I think it is narrow enough. Trouble is finding a suitable enclosure. Maplin don't have anything. RS Compoents have one that might be OK at a price:
Bopla | Enclosures and Fans | Metal and Plastic Enclosures | ABS Enclosures | ABS Enclosures
This would leave room for the BMS, connector and fuse but is probably a little too big really.
Farnells have some but they are way to expensive.
Anybody tried to make an enclosure? I wondered about polcarbonate sheet with welded seams? The advantage would be a case that was just the right size. Anybody got experience in this area?
I am wondering if I have bought the right shape battery really but too late for that unless I take it apart and reconfigure it. I would rather not do that.
Cheers, BM.
Cheers, BM.
