battery for tsdz2
tonyw
34
15
Hi. I've ordered a battery for this kit, but I'm unsure as to which connector is required. From looking at the kit, it looks like bullet type connectors on the motor. The battery supplier offers a choice of 3pin port, T Port, Andersson 1, XT60 Port, XT90 Port, Port, Anderson 2. Does anyone know if one of these choices will work, or can I just fit standard crimp bullet connectors?
peter.c
1,613
493
thurrock essex
I always cut the bullets off and solder the wires onto an xt 90 or xt 60 connector a good solution at a reasonable price
tonyw
34
15
Thanks Peter, that makes sense - I can order XT60, and if I can't find a matching connector I can always cut them off and use another style connector.
3,994
Don't use connecors, just solder the wires together, which is cheaper, quicker, more efficient and more reliable. They only provide connectors on kits for amateurs that can't solder. It doesn’t make any sense to solder a connector on because if you can solder a connector, you can solder the wires together.
