Battery location
whiteturbo
134
25
76
Bristol UK
Hi,Where do you mount your battery's?I am looking for ideas to mount my battery's.At the moment i have them flopping about in my panniers wrapped up in my waterproof trousers, so less than ideal. I use LiPo's so its usually six times 5000mah 5s. Three in each panniers wired up in parallel then connected both sides in series so i end up with 15amp 10s(36v) but i feel i can do better.
Best idea so far seems like two Turnigy pick n pull hard cases from hobbyking at about £25 including postage. Trunk box's looks good but not sure about it being so high up.
What are your suggestions for a neat stealthy way of mounting LiPo's, a triangle bag is out because i ride a ladies bike(cant get leg over crossbar due to an accident).Everything else looks pro/not Diy and i feel the battery setup is letting things down a bit.
5,786
This goes in a 9.95€ pannier from Decathlon. I have already broken one pannier. At the moment there is 20 Ah of LiPo in the case which makes it a bit heavy.
New in frame battery box will be built soon which will hold either 10 Ah LiPo or a 9 Ah 18650 Vruzend kit battery.
Reactions: whiteturbo
whiteturbo
134
25
76
Bristol UK
@anotherkiwi Thanks for the photo's. Case looks good but huge, what i was thinking was something similar but divided in two and put in two panniers. I have also looked at laptop neoprene sleeves packed with foam between the lipo's but it would be a bit messy taking them out and repacking again for charging,inspection etc but have decided to go that way for my emergency 8 amp setup which will be a get home if things go wrong kit.
The weight is OK as long as you get the battery as close to the wheel as possible and as far forward as possible. to achieve that, I make my own racks out of aluminium tube from Wickes. That's a 20Ah battery that weighs about 4.5kg and the bike handled perfectly.
What battery do you have?
8,792
When I use lipo I have two options, carry them in a pannier or the Additive V2 bike bag which is pannier that straddles the cross bar. I can fit up to 50ah of lipo inside.
http://www.additive-bikes.com/de/ADDITIVE-BAG-V2.html
In the rear panniers I place them in pairs and have made a snug sleeve for them to fit in out of old butyl pond liner, this gives them good protection from rubbing / abrasion.
5,786
In the pannier I use plastic washing powder boxes to protect them when only using 2.
Huge is the word but it holds everything, even an emergency charger. Those cases exist in smaller versions. I picked it because it was the exact size of the pannier.
whiteturbo
134
25
76
Bristol UK
So this is what i have gone with.
1 For short distance rides like going down town or local trips.
Its just a cheap neoprene ipad case with the corner cut off. inside is a Multistar 8000mah 6s 10c and a Multistar 8000mah 4s 10c(bubble wrapped)in series so 36v(42v) 8 amp its 9 x 6 inch and weighs 1.75 kg.
usually just thrown in pannier or sometimes in my backpack.
Two of these Turnigy boxes from Hobbyking(£9.91 each) which come with sponge that you can cut/pick to suit the contents. So each box has 2 x 5000mah 5s 20c and a nano tec 5000mah 5s 25-50c wired in parallel, one in each pannier and connected in series so: 36v(42) 15 amp each box weighs 2.25 kg so 4.5 kg total. I can also add another nano tech to make it up to 20 amps with an extra series wire i made up, i haven't discovered how far i can go yet so am a bit paranoid about running out especially as the last three miles to home is all uphill about 20% in places.
5,786
You will find that the 8000 mAh Multistar will give you about 6.8 Ah in real conditions. It will sag but just about 1 V on your steep hill. I don't see the LiPo alarms? Set to 3.6 V for the cheap ones and 3.65 V for the better ones.
Your 20 Ah (16 Ah) battery will sag a lot less, mine sags about 0.6 V in the worst climbs at full assistance: http://www.pedelecs.co.uk/forum/threads/number-two.23568/page-3#post-331791 is a 62 km ride, with hills :rolleyes:, where I measured 467 Wh used.
whiteturbo
134
25
76
Bristol UK
I find LVA's unreliable and as i always balance charge my Lipos so i know when one cell is on its way out, i charge to 4.16v and dont go lower than 3.6v(36v for pack). I am so paranoid about running my Lipos too low i carry a spare pack if im going any distance.
5,786
