bit of a technical question so i will try my best.
when my father-in-law and myself attached the kit to a mongose mountain bike there was much fiddling and messing to get it to fit but we got there.
one small casualty is the rear brake caliper is very close to the hub in the wheel. when i try to adjust the allen key that moves the inner brake pad closer to the disc i cant get to it with an allen key. the only way we could do it is to take the nut out and file slots into the very small amount that sticks out so we can use a thin screwdriver to push the bolt tighter. hopefully that makes sense.
because of this messing my f-i-l said he'd seen some calipers with a adjuster knob on but we cant see that knob to buy on it's own so i was looking at the bb7 calipers (wouldnt need the discs i dont think) but was worried about clearance.
so... does anyone have experience with this problem or have actually measurements of the distance from the disc surface to the edge of that adjuster knob?
thanks guys
thanks guys
