BBS in fsr Stumpjumper.
cycling weakly
93
21
77
Have any of you seen, or even better, built a BBS motor into a Fsr Stumpjumper & if so did the S shaped downtube cause the motor to sit too low? Also was there any problem with the gear case or chain wheel fouling the chain stay?
Steve
Steve
I did look at them because for a full suss battery space isn't bad, but then left alone because of how low slung the motor ends up. Once suss is compressed i don't much like the remaining ground clearance. :(
cycling weakly
93
21
77
I have now tried the HL battery in the medium frame I was thinking of buying, it was just too big. Maybe a side release battery would fit. A pity, as it is a lovely frame.
Steve
Steve
I've got a template of the side release if you really want to size it up?
But seriously, I rode with a guy who went for a right Burton because his low slung bbs02 grounded out on him.
Just not a clever build with motor at 6 o'clock position in my mid, especially with rear suss bottoming out on travel too. [emoji107]
