bbs01b 36v/48v
fusion.wind
33
7
Scotland
Hello,
With both these controllers costing $85:
36v 350w
48v 350w
Is there any difference in the components of the controller, or is it a bit like the 250w/350w 15A/18A programming change? I would have expected some price difference. I am curious as have some spare (identical) cells I could weld onto the current pack (with a new BMS) to change it from 36v to 42v... maybe.
http://www.bafang-e.com/en/components/component/motor/mm-g340250.html
From the spec sheet, does anyone know where the efficiency is measured from, 36/42/48v or 15/18A seeing as it states two values throughout for RPM. Mine I guess, is an earlier version (1709xxx bbs01b) as it doesn't have the 6v output for lights.
thanks.
17,315
you will need a new 48V LCD.
5,786
Hello,
36v 350w
48v 350w
thanks.
Unloaded rpm at nominative voltage/fully charged voltage
n0 (Rpm) 83/87
Loaded rpm at nominative voltage/fully charged voltage
nT(Rpm) 78/83
Efficiency greater than or equal to 80% at those rpms
Decent lights require up to and over 7 W so you just have to forget the convenience of a button turning them on and off and connect direct to the battery.
