Been on a test run
stevebills
443
I took the external battery for a 4 miles test run seems okay
I picked up a volt meter on the way and its reading 39.5 volt
when I got home and how low will it drop before I can charge it back up?
The charger still thinks its fully charged and stays green light.
banbury frank
Banned
Jan 13, 2011
1,565
Hi Steve it should take a charge I would say bad connection between charger and battery there is nothing stopping it if you have disconnected the BMS
Frank
stevebills
443
Frank
I was being thick as I forgot to join the red and black charging wires to the battery with the other output wires
and I did use 30 amp block connectors like you suggested for now it was the easiest option :rolleyes:
banbury frank
Banned
Jan 13, 2011
1,565
Hi Steve
DU
I had a customer call me the other day saying my battery is not charging only one red light asked him to unplug from the battery the light went dim the out
I said no mains he said i will unplug the TV and use that socket SURPRISE 2 red lights
DU
Frank
stevebills
443
I was thinking of runing without a Bms and Maybe get a ping when this thing packs up!
This is from 2007 and its a li-ion 36v 22ah but its never been used and stood since then.
I am suprised it still works to be honest.:)
banbury frank
Banned
Jan 13, 2011
1,565
30,857
Why not Li Ping Frank, he's got a very good record, something that V power don't entirely share?
stevebills
443
I have been told pings customer service is top notch!
I recharged the battery again Frank and its at 41.1 volts fully charged
I was wonerond what voltge it will drop to before it needs a full charge? :)
