Another Perspective on Belt Drives vs. Chain Drives
I'd like to re-examine the discussion of bel drives vs. chain drives.
While I understand that in this thread, Flecc noted that belts are less efficient than chain drives, the jury still seems to be out on just how efficient/inefficient the newest carbon, toothed belt drives are. The Gates Corporation says that their belts can match the efficiency of chains. However, I haven't seen any scientific tests assessing a belt drive's efficiency compared with a chain. Regardlesss, there's plenty of discusssion amongst regular cyclists, motorcyclists, and others regarding the merits of belts versus chains. See, for example:
Myth: Belt drive has poor efficiency
http://en.wikipedia.org/wiki/Belt_(mechanical)
BELT OR CHAIN?
I also haven't located hard figures about what the varying efficiencies mean. For example, if a toothed, belted drive is 10 percent less efficient in transferring pedal power to gears, what does that mean in practical terms--how many more minutes to go 10 miles, for example?
More significantly, there are other ways to look at efficiency. If one considers the total amount of time spent keeping a bike maintained for regular use, this might be a more accurate measure of the total efficiency of biking. I noted that another forum member, c_elder, says that he spends 45 minutes a week just on chain maintenance. That time spent trying to keep a chain in proper working order translates into a fairly inefficient system!
Further, even if chains are more efficient, efficiency isn't the only thing that cyclists worry about. How about:
1. Trying to clean mud and grit-clogged chains?
2. Derailleaur adjustments (if you don't have an internally-geared hub--required for belt drives)?
3. Cleaning oily grime from your frame, hands, and pants/calves?
4. Annoying clanking and squealing from mal-adjusted or rusty chains?
I think that one of the greatest disincentives to cycling in general is the maintainence and grime that are associated with chain-driven bikes. Having a belt-driven bike, with an internally-geared hub, and sealed bearings can bring one as close as possible to a maintenance-free bike. More riding and less maintaining translates into greater overall efficiency. And making the bike an e-bike will help the human rider overcome any inefficiencies in the belt drive system.
I'm the happy owner of a Kalkhoff Pro Connect S, but I would switch in a heartbeat to an e-bike powered with a belt drive. Just waiting for an e-bike maker to put 2 and 2 together and mate a belt drive/internal hub with a electric drive system.
