I would very much appreciate suggestions to shorten and tidy up the wiring on my build, which currently has a 'nest' of coiled cables under the bars. This Cyclotricity kit came with the waterproof connectors which seem to be called either julet or Higo (the white lighting cables will be replaced with tidier black wiring and shrink wrapped connectors):
I was thinking of cutting the plugs off at the controller end, shortening the cables at that end and reconnecting inside the controller box, whilst keeping the waterproof connections at the front of the bike (apart from lopping off the unused ones). I was also considering replacing the KT controller at the same time with one that is rated for higher amps, and going to block connectors. To pull this off I will need to work out the pin-out of the cable plugs and of the new controller. I found some info on pin-outs but not sure how standardised this all is:
A KT controller pin-out:
LED890 display pin-out:
Motor cable pin-out:
