bits for my homemade eleccy bike trailer
stuvy
17
I was looking on ebay and noticed a shop(coventry area) selling motors, controllers and batterys.
The motor i was looking at is an "Electric Motor 36 Volt 250 Watt 11T 6mm" priced at £24.49 there is a 300watt motor for one pound more! and motors upto 1000watts
The controller is "Speed Controller 300 watt 36 volt" priced at £15.49 will this work even though the watts are different?
As for batterys im open to suggestions but the same site has loads listed for around about £20 each.
If anyone wants to know the site i can pm you as im not linked to them and just looking for a cheap way of getting a push trailer together.
hech
352
27
argyll
Hi Stuvy, the prices you quote sound very reasonable, it would be interesting to check out the site if you could post a link.
The wattage discrepancy mentioned should not be a problem though not all controllers will suit every motor.
oigoi
467
7
Think this is the one he is on about
Stuvy the motor and controller would work for a push trailer, have a think about how you want to control the motor, do you want to use a throttle on your handlebars and extend the cable back to the trailer?
The batteries they have on their site look to me to be too small a capacity the biggest one was only 7AH which isn't going to get you very far. Size of battery you need depends on how far and how fast you want the trailer to push you and how hilly
Also have a think about the gearing ratios you need - the rpm of the motor and the diameter of the trailer wheels and how fast the trailer wheel needs to turn to go at the speed you want.
I would suggest gearing it so that the maximum rpm of the motor would work out at about 20mph, then when you are riding and the motor is under load it will slow down a bit to about 15mph. Might be a bit of trial and error involved
stuvy
17
hech
here's the link Electric Motors + Parts - All Parts By Type - Spare Parts
the_killjoy
I didnt know that? i had seen two wheel kids trailers and thought they were legal?
As for the throttle id overlooked that part!!
oigoi
Thanks for the info what battery would you suggest im very new to electric power so still getting my head around the Ah bits
banbury frank
Banned
Jan 13, 2011
1,565
Hi
These are the only proper battery's for electric bikes the others are meant for computer back up supply's At £25.50 each delivery FREE not expensive
Ritar RT12120EV 12v 12ah - EV series battery - Perfect cell for mobility scooter | eBay
They sell larger capacity as well
If you look at the company's web site below you will see they make 7 types off battery's for different applications
Ritar : Products
Ritar : Products
this is the brand we imported when we used gel battery's in the old days
Frank
Old_Dave
1,211
Dumfries & Galloway
Any body want to think about the reduction required, maybe cheaper to buy a more expensive motor with reduction gears built in.
Alan Quay
2,351
1,076
Devon
Last time I bought SLA's I noticed that VAT is not due on batteries for mobility scooters, but is due on batts for electric bikes. Same batts, different uses.
I managed to get some 14ah ones, specifically designed for EV's, and more tolerant to deep discharge.
They have been pretty good so far.
the_killjoy
822
226
My 2 wheel comment was somewhat tongue in cheek as surely with the motor on the trailer would it not be a four wheeled vehicle ?
Jeremy
1,010
Salisbury
Not as long as the trailer is detachable. Light trailers aren't considered to be part of the vehicle, so a two wheel one is fine. In fact, there is effectively a loophole in the law when it comes to bike trailers. AFAICS you could fit a powered "push trailer" to a bike without coming up against the limits set in the ebike law. It'd be a very grey area, but as it isn't specifically illegal, AFAICS, it might well be OK.
Could be useful for those who need to shift heavy loads around on a bike; I've often thought than a powered trailer could add a lot of versatility to a standard non-powered bike. Several times I've contemplated making a trailer with a hitch that senses when it's being pulled and uses that signal to drive the motor. This would automatically provide up hill assistance, or assistance when pulling off, but the trailer "shove" would stop if you applied the brakes or were going downhill.
stuvy
17
My initial idea was to build the push trailer as a ruck sack and rear panniers are not enough for the weekly shop. seeing as tescos is the same distance from my work but the other direction. As is always the way with life there is a monster hill on the way back which see's me down to my highest gearing and is a bit of a grind to peddal up when fully loaded with shopping!
Plus i like to take my bike off road with a mate every now and then and dont want the hassle of unstrapping the batterys and potential risk of damaging the motor as im still into my XC. After writing this i know it must sound odd but cycling to work at 5am especially when its piddling down with rain is certainly not fun, plus i typically end up sweating and dont feel too fresh before i get to work
Thanks for the battery suggestions
Jeremy
1,010
Salisbury
Just a thought
Tescos do deliver :p
Our local Waitrose have covered bike trailers you can borrow (or maybe hire) to take your shopping home in, I believe. Certainly there are always a few of them in the entrance that look as if they are available (green and branded, but still OK if all you want to do is shift your shopping).
stuvy
17
they look like they would buck and jump around like mad over bumps and kerbs!
Old_Dave
1,211
Dumfries & Galloway
If it jumps then it means you have to put more shopping in it... Lol
Maybe go to Wicks for some paving slabs.....
30,857
They are actually very good to tow, and a long established and popular design. The one fault the design has is that they can tip over on fast corners if the weight of the load is even all the way up, so with a high load riding slowly around bumpy corners is advisable.
