Brake cable Vs gear cable
Wayners
506
106
56
Gloucester
Are brake cables the same as gear cables? I ask because on my current conversation the original gear cable is thinner than the brake cable.
Jodel
182
150
There are several differences I believe.
Gear shift inner cables are usually either 1.1mm or 1.2mm thickness. The nipple at the end will also be different for Rapidfire / STI / twist grip shifters
Brake inner cables are normally 1.5mm or 1.6mm. MTB / STI nipple ends will be different.
Reactions: Wayners
thelarkbox
1,634
504
oxon
Yes! brake cables will probably undergo significantly more strain and can probably stretch a bit while gear cables will be under a limited range of strain and will be required to remain under strain indefinitely without stretching. so are probably wound differently. oh and different diameters too well this end at least.
Reactions: Wayners
