This was purchased around Nov 2014 from Halfords and has never been used and would make an ideal donor bike for a conversation.
The plastic to the right in the picture is what the bike was wrapped and sealed in and was only removed to take the photo.
Offer in the region of £350.00
Spec below......
Approximate Weight (KG): 13.1kg
Brake Type: Hydraulic Disc Brakes
Forks: Suntour NCX-D LO Lite
Frame Material: Alloy
Gender: Mens
Number of Gears: 20
Pedals Included: Yes
Suspension: Front Suspension
Wheel Size: 700c
Cassette/Freewheel: SRAM PG1050 12-36t
Chainset: SRAM Via Centro 48/32t
Fork travel: 63mm
Front Brake: Avid DB1 Hydraulic Disc Brake - 160mm Rotor
Front Hub: 9mm QR - 32 Hole
Front Mech: SRAM Via Centro - 2 Speed
Gear Shifters: SRAM Via Centro - 2x10 Triggers
Geometry: Boardman Multi-Surface Hybrid
Handlebars: Boardman E4P - 680mm(S) 700mm(M,L) - 31.8 with 15mm Rise
Headset: FSA No.10P 1.1/8" - Semi Integrated
Pedals: Wellgo Alloy Body - Steel Cage - 9/16"
Rear Brake: Avid DB1 Hydraulic Disc Brake - 160mm Rotor
Rear Hub: 9mm QR - 32 Hole
Rear Mech: SRAM Via Centro - 10 Speed
Rims: Boardman E4P Doublewall - 32 Hole
Saddle: Boardman E4P - Chromoly Rails
Seatpost: Boardman E4P - 31.6mm - 350mm with offset
Stem: Boardman E4P - 90mm(S) 100mm(M,L) - 31.8 with +/-7 degree rise
Tyres: Schwalbe Tyrago Kevlar Guard 700c x 37c
Spec below......
Gender: Mens
Number of Gears: 20
Wheel Size: 700c
Fork travel: 63mm
