Hi guys
I was checking out the wiring in the throttle to see if I could fit a reed switch to the brake lever. I decided against it at the moment because I didn't want to permanently wire the throttle to the brake lever.
Well I began to put it back together and in doing so I broke a lead on the transistor (I think thats what it is) right at the base - no chance of soldering it back on
I'm hoping to get a new transistor but i can't find any online that matches the number - S49E947
Anyone any ideas or should I just order a new throttle - that would be a shame as I had managed a good imitation of fleccs throttle mod.
John
PS - Came across this Pedelec, Elektrofahrrad und E-Bike - Power grip with LED 36v Gas LED 2teilig36
Looks very similar to the original except its a half throttle. The only doubt I have about is that it says its for controllers with hall sensors. However as I understand it the 8 fun motor and the controller are "no hall". Do you think this will work?
John
