Sky is very good and her good English and communication skills make the whole transaction less frustrating than some other Chinese contacts I have had to deal with.
Sky was more responsive than most American companies. Smooth transaction so far.
Are you sure Sky is a woman? I knew a guy named Sky. It's one of those names that could be male or female.
What battery are you going to use ?
Not a clue, that's my next thing to research to death. From the little that I've read so far, it seems maybe I should look for something a few amps higher than 36Volts, like a 39Volt battery. I'd like it to be below 300 watt hours since that's the maximum size allowed on U.S. airlines.
... sorting out the controller with an umbilical plug so that it could be mounted off the bike/in the bag. ... the only place it seems to fit without effecting the fold and keeping the wires up front is on the main steerer tube.
Your controller on the handlebar stem is the same location that nycewheels has their controller.
[video=youtube_share;ChoVvbQ1_lo]http://youtu.be/ChoVvbQ1_lo[/video]
I don't know the weight of nycewheels controller, but when folding the bike the stem seems heavy. So much so that I questioned them whether the controller could be located in the bag. But it's also much larger and bulkier. I don't know how much the Goldant controller weighs, but it looks tiny in comparison. I toyed with the idea of getting the 98mm Goldant motor with built-in controller just so I wouldn't have to deal with it.
The throttle option certainly makes for a more lazy ride ...
Funny that you should say the Goldant keeps you from choosing to a lazy ride. When I test road the nycewheels bike, I could totally see myself throttling all the way to the coffee shop and back. Sounds more like a bicycle-like riding experience which I like a lot.
Speaking of comparing throttle Nano to pedal Goldant. Were you aware that electricwheel offers an option to turn the Nano into a pedelec? It claims in it's FAQ that for 50 pounds, they'll add a pedal sensor to make it "legal" in the European countries that require pedal sensors. I imagine these are laws that aren't enforced, but I guess I was surprised to see the Nano could be throttle and/or pedal sensing. Not sure if it works the same way as the Goldant.
I have a few more mods to do re the switch and the cutout brake and will post details as and when I do them
Looking forward to the cutout brake and switch, because I'm still not sure what that is but I need to keep reading. I assume this is to turn the motor off quicker for sudden stops. I recall you talking about adding a switch to turn the assistance on and off so that you could use the bike without assistance. I assume that's for convenience from having to just unplug the battery.
Would you be able to do estimation on battery consumption for your work/home commute in comparison to the Nano? I'm not sure if you've ever measured how much juice the nano used on average for the commute. Sorta like an estimation without a cycle analyst to figure out the Wh/km. It certainly seems very similar to the Nano in performance based on your review.
