C965 display showing ( ! ) and motor cut out
Oscdav
27
9
Hi all'
Need some help. The display on my Bafang 750w is showing the ( ! ) sign :):mad:, and motor is dead. Although I have checked the brake is not engaged and also disconnected/reconnected all the cables.
At the time I was going over some very rough tracks at speed. Can anyone explain the cause, and what I might need to do to rectify?
Thanks in advance, Oscdav.
Fordulike
3,802
1,537
Have you tried disconnecting both brake sensor Higo connectors and going for a ride to see if problem persists?
Be careful when riding without brake sensors connected though. Only go for test ride!
Oscdav
27
9
Fordulike solved this easily the same day... dislodged brake sensor:rolleyes:
Thanks!
