I would just like to confirm some facts before i get a bit too carried away and try something that might not work.
At the moment my bike has:
24v motor
24v controller max output 14A
Wuxing throttle and brake cutout levers
24v 9AH Li-ion battery
Now the maximum amps that the controller can supply seems low, so i'm thinking of upgrading to a better spec one.
I'm assuming if the controller can supply more amps, that the motor can draw more power on hills. The only downside being less range.
** Please can someone correct me if my facts are wrong **
If this is a possible worthwhile upgrade, then i don't think it would be difficult.
The Wuxing components should have the correct connectors on the end.
The motor and the pedelec can be worked around if they don't have the correct connections.
24v motor
