Can you fit a throttle to a Bosch CX motor?
Deus
328
143
Dewsbury
Can a throttle be fitted to a Bosch CX ? a throttle that gives instant power not one where you have to rotate the peddles first?
6,319
no as the software is locked you cant even use a 3rd party batt as it has to talk with the motors controller to even turn on.
Reactions: Deus
Deleted member 25121
No, there's nowhere to connected it and the controller firmware isn't designed to be able to read it.
Reactions: Deus
3,986
How good are you at hacking? It's possible to reprogram the walk assist speed so that the walk assist button works like a full-speed push-button throttle. Without hacking, you need the Bosch software, cable and password to do it.
Reactions: Deus
Deus
328
143
Dewsbury
Thanks for the replies what about other motors like Shimano or Brose etc? or some of those come with throttles anyway ?
Fat Rat
1,903
726
UK
I think you need to look for something other than a crank drive
Non of them are designed to work as throttle units
If I was you I would look into hubs instead as it defeats the object of the crank drive to have a throttle
Reactions: Deus
2,674
You should get instant power just by pressing the pedals; one advantage of torque sensing. Maybe not as much as you want though? Or at least, instant torque.
Reactions: Deus and ebiker99
Deus
328
143
Dewsbury
its a friend who is wanting a throttle on his first ebike purchase he has tried my Bafang BBSHD set up and seems to think he needs a throttle now
6,319
swap bikes ;)
Reactions: Deus and Woosh
