Car Jump Starter as backup pedelec battery?
peterjd
213
52
Hi, I've got one of those 'Car Jump Starter' batteries which is doing very little most of the time. Its stated capacity is ~ 70Ah at 12V. If I had a suitably rated step-up converter to say 40V would it be feasible to use it as an 'backup' supply for my nominal 36V pedelec. I can already run my pedelec for limited runs on my 3 - 5 Ah 36V tool batteries. Peter
3,888
70Ah at 12v would weigh about 6kg. Is that how big it is? Most of the ones I've seen are probably around 100wh.
peterjd
213
52
I agree it sounds implausible, given it's tiny and weighs about 280g, but its label has 'Battery capacity: 69900mAh' Chinese hype? Worked brilliantly as a car jump starter on my Jazz hybrid.
3,888
280g is about 50wh max. I would translate the Chinese as 6 x 3300mah 3.6v cells. For comparison, the average 18650 cell weighs about 50g and has around 10wh in it. Lipo and LiFe have a bit less. The jump starter I opened had a single 3S lipo in it.
2,834
Maybe it meant 'Battery capacity: 69900mWh'. Or maybe it's just a random number.
8,754
Certainly not 70ah most likely nearer 6000mah .
8,754
8,754
I use a graphene lipo for the odd jump starting . it is only 52wh,
4.4ah x 12v.
Az.
2,170
983
Plymouth
Don't complicate simple things. It sounds like you need a bigger bike battery. Bike battery, not a pocket size powerbank.
8,754
The small pocket power packs are ideal for instant punch often 600a or more , but not much use other wise unless using at a default 12v supply.
Ghost1951
2,281
1,026
I bought an ebay mini torch with a useful pen clip to keep it in your pocket, that claimed some vast luminescence (1.2 million Lumens).... It's not a bad pocket torch for the money - a touch over 4 quid, delivered, but it isn't a searchlight for sure.
Benjahmin
2,669
1,784
70
West Wales
I've got one of those jump starter things. Claims to turn over a 3litre diesel or 6 litre petrol engine. It's a bit smaller than a brick. I use it to power a sat nav when I'm away camping - sits in my Carradice handlebar box.
3,888
There are different ones with different sized lipo batteries in them. That's all they are, with a charging system and something to protect them from being reverse connected.
peterjd
213
52
OK, I get the message. I will be satisfied with its use as a fairly effective torch in addition to its proven car starting ability. Thank you for the advice.
harrys
393
107
Chicago, USA
Efficiency might be poor with one and a DC booster. I once bought three on clearance, and hooked them in series, It worked OK for a 250W ebike, although I didn't know at the time that a total voltage from a series combo might blow out the BMS circuits.
That never happened, but I left the bike out in the rain and that destroyed the charger circuits,
