Hello Baz.....Are the BMS boards coated ??? if so makes things a bit harder to repair !!! i know some people boil in water the pcb's to remove the resin but it can be risky which might damage some components but then again the pcb is useless if it has a fault so i guess there's not much to loose by removing resin by hot water !!! i noticed the bottom bracket on my working vulcan does protrude somewhat....i measured the width and it was 137mm as stated by halfords...im not sure if i can get away with a bottom bracket that is a different width ???
Dave I have these Two batteries attached.
They are for the Carrera after your model but before the latest ones.
They are both balanced the far one in the picture is outputting 40V at the discharge port and will run a motor using a KT controller but the BMS will not allow it to charge from charging point.
Three lights light up on the on and off switch and the 4th just flashes..
The second one the one with the Suntours controller plugged in is also balanced and gives the 40V only when the charger is plugged in at the discharge port.
I have a third BMS that is doing pretty much the same thing when I swap it onto either battery pack .
So I think the BMS is not allowing the battery to charge and the charger just clicks .
I also have one of these chargers that some ass-w—-propped me off for sent his old one back on e bay before I security marked my stuff .
Do you want to see if you can do anything with these I will drop them down Monday ?
I once sold a brand new central heating controller on ebay...and the buyer wrote and said the lcd display was not coming on...and he lied and ebay refunded him...when the item was sent back to me it was the buyers old controller and the plastic case was so badly chewed......and it was a different model to what i had sent... i then sent ebay photos of the new controller that i sent him and ebay refunded my money that i lost....are the battery packs 36V ??? if so the the pack should normally read between 36 & 42V
With the charger plugged in there is voltage 42V across the the two terminals on the BMS that are connected to the charging port and the discharge port which are joined .
But the voltage is flickering from 42V then less flicking on and off like an intermittent fault.
And the charger is clicking.
So the charger is delivering voltage but the BMS is not allowing it to charge the battery and the light on the charger is staying green and not going red ..
I just discharged some of the other battery on a motor down to 36V now that also will not charge and is doing the same thing .
Have you tested each battery one by one....each battery should be around the same voltage...normally each cell if fully charged should be around 4.2V ....if any of the cells are low then they need to be replaced....but the important thing is that each cell must be around the same voltage....so any cells you replace should be around the same voltage....also if any battery pack is too low due to over discharge then the BMS will not charge the batteries...i would then normally disconnect the BMS and using a bench power supply charge the battery pack direct setting the current limit to around 500 mAH. and power supply voltage set to 42V for a 36V battery pack.
The battery packs are at 40V volts .
Each cell group was charged up to 4V I did not push them up to 4.5 v as last time or first time I done this I blew a cell group.
I have them mapped out and each cell group is at 4V ie 10X4 =40 v
I have disconnected the BMS re connected and plugged into a controller. So the comms between all three components should be communicating which on one they are as the battery works but it will not charge
At 40V. Across the direct battery terminal’s I would have thought there is enough voltage to wake the BMS without pushing it any further ?
Forgot you do not need an original Suntours BB as on the Raleigh Array they have the longer silver BB it just does not have those big collars on it they are not needed
i normally charge to about 4.2V which amounts to 10 x 4.2V = 42V as the charger output is normally rated at 42V....yes at 40v the BMS should charge the battery !!!! so its looking like the BMS is faulty....i once had a battery pack which i had to charge via my bench power supply bypassing the BMS ....once charged i reconnected the BMS and within just a few days the BMS had discharged the battery pack to 0V...faulty BMS can cause different faults....i think your pro blems are caused by the BMS....i think the companies use such low quality components that fail so quickly so you throw it away and buy another battery...thats the way they do business. i think your BMS boards could maybe be repaired as long that no micro processors are involved. Are the boards coated ????
When you say about the collars on the suntour bottom bracket do you mean that plastic rings that cover part of the axle ??? so what axle do you think will do the job ???
