hi, as a newbie, just purchased a small bottle of lubricant, makes whisky look cheap, do any of you use any products that are as good but cheaper? Many thanks
Brian
Brian
Muc-Off Bio Dry Lube 120ml | Tredz Bikes
Save 29% - Muc-Off Bio Dry Lube 120ml £9.99 or available with 0% APR finance on baskets over £99. All Bike lubricants are delivered free to the UK mainland*, 365 day returns & Price Match. Buy Now.www.tredz.co.uk
they sometimes have it in lidl and aldi think it was 4.99 last time i got one
Thanks all helps![]()
Motorex Chain Lube Off Road 500ml Spray
Motorex Chain Lube Off Road 500ml Spray - Motocross Oils, Lubricants & Cleaners Motorex Chain Lube for Off-Road use is used by top factory teams worldwide, by independent pros and by top amateurs who demand the best performance from their race machines. The complete Motorex line includes a broad...evenstrokes.com
I use this on my motorbikes so it's always on hand for the push bike. Doesn't fling off
I use the wet lube stuff which is quite pricy I agree. However my ebike has a stainless chain so the only place its really needs oil is the roller. Only a very small drop is required per roller as per the instructions. I clean and lube every 10 days or so. Still have lots of left and the chain, after 1600 miles has virtually no wear.Thanks it really is helpful, I do appreciate your. time in replying
3 in 1 is rather too good at attracting dirt and grime, so it doesn't do a very good job unless you clean and reapply quite frequently. Also can be mucky on the trouser legs if you don't have a chain guard.Dry lube, wet lube, pushing 70 now what happened to 3in1 oil?
Cheaper.......When the bottle is empty, refill with 3 parts paraffin (kerosene) to one part motor or gear oil. Shake the bottle before use.hi, as a newbie, just purchased a small bottle of lubricant, makes whisky look cheap, do any of you use any products that are as good but cheaper? Many thanks
Brian
Your workshop must smell funky! Gearbox oil smells like cat pee.....I've been using ordinary gearbox oil (Hypoid 90) on my bicycle and motorbike chains
Interesting post!Cheaper.......When the bottle is empty, refill with 3 parts paraffin (kerosene) to one part motor or gear oil. Shake the bottle before use.
Diesel or white spirits have been used instead of paraffin.
Not the stuff I use - Castrol or Shell. I keep my bike in the house. Nobody has ever complained. Maybe your cat got at yours!Your workshop must smell funky! Gearbox oil smells like cat pee.....
