Chain ring change size on Shimano steps
Nutz
54
Edinburgh
Hi folks
I've had a Raleigh Strada E for about 2.5 years now. It's done 3200 miles and I'm pretty happy with it.
There's one thing I'm thinking of changing, though and that's the front chain ring.
My commute is downhill most of the way there and uphill most of the way back. I never use 1st gear, rarely 2nd, but I do spin out too soon for my liking.
My bike has an Alfine 8 speed with a 18t sprocket at the back, and a 38t chainring at the front. I know Shimano also do a 44t chainring for the Steps system, and I was thinking of changing to this to improve the gearing.
Any thoughts on this? For instance, does the software need to be told about the chainring size?
6,319
no but a 6t bigger front sprocket is a big change so will slow you down on climbs as not have enough gears the other way :)
Nutz
54
Edinburgh
RIght, yes I was wondering about that. So 38->44 is about 15%.
I was hoping that this would mean something like 1st becomes what is currently 2nd, 2nd->3rd etc and I get a useful gear at the top end. I've been trying to find a calculator but can't make sense of what I've found online.
Is this naive? I've read I can move the rear from 18t to 16t using a Nexus sprocket which would be less of a jump so that's also an option.
KirstinS
3,224
899
Brighton
8,226
Shimano nexus/alfine 8 sprocket to gear ratio's .
16t = 10/30 10,11,13,16,19,21,25,30.
18t = 11/34 11,13,15,18,20,24,26,32.
19t = 12/36 12,13,16,19,22,25,30,36.
20t = 12/38 12,14,16,20,24,27,31,38.
21t = 13/40 13,15,17,21,25,28,33,40
Nutz
54
Edinburgh
Thanks everyone for you help. I made the change from 18t to16t on the back, and it has worked a treat.
I'm happy with the slightly higher gearing, and I also installed an adjustable stem to raise the handlebar height. My bike is much better with these two changes, and I wish I'd done it a long time ago!
Reactions: Artstu
