Changing Gear
geostorm
297
can anybody give advice, as to uprating 3 speed on Ezee Sprint if i could do transfer with 8 speed , or possibly convert to derailier gears any pitfall to watch out for ? thanks
30,850
The Sprint originally came in either 3 or 7 speed hub gear versions, but you could convert to the 8 speed hub gear without problems.
To convert to deraileur you'll need an add-on rear mechanism hanger which Shimano make. This can be difficult to get hold of but St Johns Cycles (SJS) have normally stocked them. This is a photo of it, it sits in the rear spindle slots in the frame:
The conversion to derailleur is slightly more difficult since you need to choose all the bits to be compatible and will need a complete new rear wheel with a cassette hub mounting for the rear sprocket set. The 8 speed hub gear conversion should be very straight forward if you get a dealer to build the hub into a rim for you.
