Chargers, all the same ?
Tubamanandy
267
38
63
Are chargers all basically the same ?
Would it be fair to say that as long as your charger gives enough power, it's the quality of the BMS
that controls how well the battery is charged ?
WorldClassAccident
27
13
I don't know but I would guess...
...they are basically similar but put out different power. I have two iPad chargers, one charges my iPad in about an hour the other takes about 4...
...better chargers have some anti-spike / surge protection built in...
...really cheap ones will have rubbish components and build quality and are best avoided
30,859
Most e-bike lithium chargers tend to be 2 amp rated, but a few are faster chargers at 4 amps rating. Otherwise they do the same job and it's only the connectors that need changing.
The most common brand over the years has been HighPower of China, branded HP.
Alan Quay
2,351
1,076
Devon
So its just the amperage & connectors that really differ
And the voltage, and the cutoff point.
Chargers are actually quite different for different battery technologies.
Some charge at a constant voltage (SLA) and simply allow the voltage to equalise. Others (nimh) look for a voltage drop which occurs at the end of charging. Some charges use a constant current, and others do a bit of both.
As far as I'm aware Lithium chargers use a constant current, and presumably stop when current draw drops off.
