You need a converter from 36 volts to 5 volts, preferably capable of supplying the standard 500 mA for a USB outlet.
These are an oddity and I can only find one at
Powerstream in the USA at $30.75. Scroll down the page to the block of four DC/DC converters from 24 to 120 volts and click on the centre link. Then click on the 48 volt version numbered PST DAA 4805. This handles a 36 to 60 volt input for 5 volts output. On the second page of the buying process, make sure you scroll down a bit and select a lower price post option, the USPS Express option is what I use, about 12/15 days to delivery.
To wire the USB socket that you use to supply power from the converter[FONT=Arial, sans-serif]
, view the mouth of the socket where you plug in, with the four metal contacts above the plastic centre support, then the contacts are numbered 1 to 4 from left to right, so you wire to contacts 1 and 4. [/FONT]
Contact 1 = +5v [/FONT]
Contact 2 = USB - [/FONT] signal
Contact 3 = USB + [/FONT] signal
Contact 4 = - (Negative/ground)
[/FONT].[FONT=Arial, sans-serif]
[/FONT]
