Cheap Chain
musicbooks
719
29
Hi Folks,
Any ideas where I can pick up a cheap chain for the Agattu? I have a link that refuses to stay put:mad:
Also, is it fairly straighforward to replace?
BW
musicbooks
Mussels
3,207
Crowborough
Count the links in it to see what you need.
These are 112 links for £4, if you need more links you need to think about how you want to join them.
Have you had a look to see what 50cycles charges for them?
30,848
Any cycle shop will have 1/8" chain in stock, usually in a choice of two qualities, though they will be dearer than the price Mussels has quoted. They are usually a bit short of the length you need for the e-bike, but a local bike shop will often be able to throw in the extra bit you need from their cutoff bits left when fitting new chains.
They can also supply the chain tool you need, and the page below tells you how to use it:
Using a chain tool
musicbooks
719
29
Hi Guys,
Thanks for the advice. I contacted Lloyd at 50c and he is sending me out a replacement chain, free of charge. Can't say better than that.:)
BW
musicbooks
