Hi guys, I have a cargo bike like this one - http://www.cargobike.se/produkt/Cargobike-Classic-Electric-
I have bought a new controller to test out from KT but it seems my motor is sensored and I bought the non-sensored controller. Nonetheless it would be nice to test how the bike performs with sensorless controller. I am a bit hesitant to start cutting away wires since they look so nice and tidy in the bike. What I would like to do is figure out where to buy connectors like the ones I have attached to the current controller so I can swap in the new one and test. If things don't go well I can always revert back.
Pictures of the connectors below:
Engine connector - 9 pins (3 + 6) - Seems to be the one here: https://www.ev-power.eu/EVBike-WheelKit-Parts/SPARE-PART-EVBIKE-Extension-HUB-connector.html?cur=1
PAS connector (6 pins) - I assume only 3 are used here
Brake sensor + controller (8 pins, splits into two cables further up similar to the PAS cable 6 pins) - 5 wires to controller, 3 to brake.
Any tips to where I can find them? I googled around but could only find the motor cable, and in reality I only need the female ends.
By the way this is the controller I want to test. I have the lcd as well:
http://www.pswpower.com/peng/iview.asp?KeyID=dtpic-2016-3F-43TE.50CTN
Cheers
Cheers
