I took a peek at the controller contained within a box under the crank. The box is welded as part of the frame and contains all the wiring too.
I didn't expect it to be branded or anything special and i was right.
It does have a label on it with some specs and a serial number.
If anyone can point me in the right direction to any more info on this controller, then that would be great. Pessimistically i'm not going to hold my breath though
24v system
Max 14A
Rate 7A
Low Voltage 21v
Throttle adjust 1.2v - 4.4v
Serial number: WS X09050019870
Can someone explain what the throttle adjust figures mean please.
Also does a max of 14A mean that i shouldn't run it with a battery of more than 14A capacity, or is this the max it will provide to the motor whatever the battery capacity?
24v system
Max 14A
Rate 7A
Low Voltage 21v
