My new controller has two live connections for the battery. Can anyone tell me what he thinner one is for? No manual .Described as electric lock line. What does that mean?
It's very rare for controllers to give problems unless you misconnect something. Show some photos of what you've done.OK thanks. I'm sure I've wired it up correctly but the motor won't run. I've checked with a multimeter and now convinced the controller is a dud.
I don't think so, but that's not at all clear what you mean. Draw a picture. From the switch, one wire would go to the battery positive and the other to the ignition wire so that you can switch the power on and off to the ignition wire. You don't need a switch if you have a switch on your battery, in which case you join both the thin and thick wires to the battery positive.So am I right that positive wires, thick, thin and both on/off switch wires connect to the battery positive?
