Conversion kits and battery
Peter1972
12
Hello. I want to buy a conversion kit from eBay. 1000w rear hub 48 v battery. LCD screen. The issue I'm having is the connectors on the parts actually matching. I've noticed that there are various types. So my question is does anyone know what will work together and from what seller. I have a budget of £400 for the parts.
Many thanks
3,994
You're going to have a lot more problems than connectors.
£400 isn't enough to buy a kit and a battery that can supply 1000w. The cheap 48v batteries can't provide enough current. Expect to pay around £350 for the battery alone. You'll have to pay around £50 duty, etc, if you buy one from China. If you're looking at ebay, type 48v 1000w battery into the search, not just 48v.
You will also need to factor in decent hydraulic disc brakes, which means rotors as well as calipers and levers. When you're travelling at 30 mph with a 1000w kit on your bike, it takes 5 times as much energy to stop your bike compared with travelling at 15 mph on a normal bike. Pedal your bike at 15 mph, then see how much effort it takes to stop quickly, then multiply that by 5 to get an idea of what's involved.
Have you include the price of two torque arms, which will also be necessary?
To answer your question, you will always need to change/add connectors to your battery unless you buy the whole kit, including the battery, from the same supplier and you confirm with them that they have matching connectors, which they often don't.
Is it time for a new plan? Sorry if I spoilt your dream, but life isn't always simple.
Reactions: D C
Peter1972
12
Is it time for a new plan? Sorry if i spoilt your dream, but life isn't always simple.
Thanks for the information. I did type in 48v 1000v and there are some for £220 they are 12.5ah. What would you recommend? is this not sufficient then? And the 1000w hubs come in below £200. I do understand that sometimes paying little more for higher quality components is a better option. As for the disc brakes they will be on the doner bike I use. The budget of around £400 was just for battery and hub. So am I looking more at £550?
Kind regards
2,835
The 1000w are illegal for use except on private land with no public access. Also they will be direct drive and get through battery really quickly, so extra reason to need expensive batteries.
Peter1972
12
Thanks I know the law on this. I found this company that ship from Germany.
Seems reasonable. Will any of those batteries be sufficient. Have you got any recommendations?
All the best
KirstinS
3,224
899
Brighton
Kind regards
The problem with buying a cheap direct drive kit is they are very power hungry indeed. Forget the 1000w moniker. Most 250w nominal legal hubs can put out at least 500w and many 800w. Most are geared and use battery at lower amps
In the same manner one 12ah battery is not the same as another 12ah battery. That's just how much is in the tank
How quickly that 12ah can be delivered is very important too. That depends on the actual cell specification and the BMS inside. Cheap chinese cells will perform badly and die quickly on what you are planning. You need a quality celled battery with BMS capable of giving high amps (not amp hours). These are expensive at c400 quid
This is what VFR is telling you
A better way to go about this is tell us what you want to achieve, on what terrain, mileage, your weight and so forth.
This isnt about quality but matching the requiremets of the motor to the battery. Do it wrong and you will be chucking money in the bin!
Reactions: D C
Peter1972
12
Peter1972
12
[/QUOTE.
Thanks. I'm 19 stone. I just want a little bit more power than I currently have at the moment. I have a 500w conversion with a 36v battery which does ok. I ride to work about 11 miles round trip. It will get up to 19mph. But struggles on hills. So I'm not looking for mega long range or mega speed. Just a little boost in speed and climbing hills. Any help is appreciated as I realize the minefield the internet is with cheap kits.
3,994
can you tell us exactly what motor, controller and battery you have. There are probably better and cheaper solutions than that 1000w kit.
The problem with those 100W kits is that they're designed for continuous 30 mph. if you run them at normal speeds, they're inefficient and overheat. With your weight, I can't see one lasting very long before something burns. You need a slow high torque solution.
Peter1972
12
So would it
I have no idea what make of wheel ,battery, controller I have. All I know that it's a 500w hub and 36v 10a battery I think. It was a conversion kit that was fitted by a company that are no longer trading!
Peter1972
12
Show us photos.
I appreciate your time. But I can't see how showing you a picture of my hub and battery will help. I've told you the specification of them. You won't get more information from a black battery and black hub. They all look the same!
KirstinS
3,224
899
Brighton
Because he is an expert. They look the same to you
Reactions: vfr400
8,782
I'm not even going to bother....
Reactions: vfr400
hech
352
27
argyll
So is an 'Esteemed Pedelecer' better than an 'expert' pedelecer or is it just the way one talks on the Forum these days?
They all look the same to me too, similar even to our designs here at NASA for getting our lads up and back home from the space station on the cheap. Chinese astronauts are lighter in general too, though many cant play the guitar so good.
3,994
Long time, no see. Welcome back. I used to like your posts. I think esteemed pedelecer is about right for you.
hech
352
27
argyll
Why thank you Sir you are too kind. But esteem is a word I am not worthy and pedelecer not a word at all.
jonathan75
794
213
Hertfordshire
They really don't all look the same, and there is much information to be had from photos. If you don't want to stick out your tongue for doctor, fine. If you don't think people here know anything useful, you're wrong, but fine. But please don't tell doctor that there's no point in sticking it out because all tongues look the same. That's just exasperating.
Peter1972
12
I'm sorry if I came across as dismissive. I did come here for advice. I will stick my tongue out later!
