I couldn't help tinkering with the Cyclamatic again and think I have taken the controller mod as far as I can go. That is without blowing something up
I do believe the battery contains Headway cells, although like a lot of Chinese products, might be copies. Therefore the battery should be pretty resilient.
Only time will tell, and to be honest i'm not bothered as it's well out of warranty.
The shunt wire used to have a little bit of extra solder on both ends, but now I have filled in a whole corner with solder.
On the road test it blew the 20 amp battery fuse, but after replacing it with a 25 amp one, it is now stable.
The results?
Yet more pulling power and grunt
I expect the total mileage on a full charge to decrease and my battery is getting on a bit anyway, but it's been a worth-while insight into how everything interacts with each other.
The results?
