I have asked these of the Cyclotricity team but it looks as though they are too busy at the moment to answer which is fair enough. Thought I would get a quicker response from the forum! I would like to order my 250w/500w kit today ideally.
- My brake levers are integrated into the gears shifters. Do they supply a sensor setup instead of a brake lever for their kits?
- It's not clear if the LED handlebar setup is unable to unlock the 500w full power. The description on the kit suggests that the LCD can do this.
- They give an option to buy a freewheel, but I already have one so assume this will fit (it's definintely not a cassette so should be fine)
- They supply an 11Ah rack battery for £225 but don't say what sort it is. Is there are better value battery that may be compatible for a rack?
- I think I can make a torque arm quite easily to save the £20.
