Disabled cyclist; with one bad choice behind her, needs help with a new bike
Katymac
177
46
57
Norfolk
I know what I don't want (I already have that)
I need a low step through, with shedloads of power to take me not very fast, everywhere, even up hills
I needs to be light, with big wheels, suspension, very sit up and beg
In fact a complete cross between the 2 bikes I have
The crusa is too heavy and all the weight is at the back so it's unstable when I walk with it or load it on the train
The fazua is too big for me I can't get my leg over the bar and my legs aren't strong enough to register on the torque/motor
Peter.Bridge
1,864
828
Would that work like the crusa?
I think it has a torque sensor, so you would probably want to install the throttle as well as per the Woosh page
"Please note that with torque sensor, the motor output is proportional to your pedalling. You have to pedal harder when climbing a hill.
If you have some physical issue, add the throttle kit."
Baz the balloon man
556
32
Hi I have a brand new Raleigh Array Step Through not used .
And I am building a new Arrary with stripped out Suntours system.
Planning a Bafang Rear Drive hub choice of Two with 48V HL Battery with 17amp KT Controller and screen .
EX Display bikes unused but may have the odd mark or scuff post pictures later of the step through .
Step Through I think would be good for disabled riders but the Array in the picture is low to solid bike but I have already stripped out the Suntours components
Katymac
177
46
57
Norfolk
OK
I am now pretty set on buying a lightweight stepthrough/low step (god they are hard to find) and adding a motor
My favourite is an Islabike Joni, followed by an Islabike Janis
However I can't find a Joni in my size!
I've been having lovely conversations with a bike shop in "Scotland" who will sell me one but can only give me a photo from a magazine ;) I didn't fall for that!
Katymac
177
46
57
Norfolk
You guys have all been amazing so far - do you want to hear more planning/building in the future or shall i wait till I have a bike that works?
matthewslack
2,594
1,671
Always both interesting and useful to hear real world experiences, all the way from research/choice to riding experience, so post without limits!
The Isla models you mention look somewhat delicate in frame design to me. Not much meat in the bottom of the step on the Joni, and rather slender upper member(s) on the Janis. I'd be staying away from the more powerful conversion kits with those bikes.
Reactions: Katymac
matthewslack
2,594
1,671
Apart from the "can't afford it anymore" but
What's wrong (for me) with this one
They've tried really hard and succeeded in keeping the weight down. Only 16.5kg, impressive.
A lot of that is the carbon fibre, and a little is the use of expensive components that are a bit lighter than lesser versions i.e. Shimano XT.
I'd be disappointed with only a 400Wh battery, but that is only a problem if it can't manage the range you need. Small saves weight, but probably only half a kilo compared to 500Wh.
You'd have to think about the motor: it is only the 55Nm Performance SX, presumably chosen for lightness. Not as beefy as the CX.
Biggest gripe of course is the £4500 price. For me I'd say 'well done guys, impressive weight' and then buy a heavier 625Wh, Performance CX bike for probably not much more than half the cost.
Katymac
177
46
57
Norfolk
Yeah £4k!!
I really need to get something sorted
I want a bike shaped bike otherwise I'd be sorted - I'm going to be a long time in a wheelchair/scooter so I want my pretty bike now
A trike would be heavy as * so it won't increase my mobility & now I can't even open the sodding car door, so driving will only work if there is someone there to let me out ffs
Sorry pity party!
Seeing/testing a joni at the beginning of July & spending far too long each evening googling bike weights and arguing with idiots who think showing me a bike picture from a magazine (or even the manufacturer's webpage) will make me believe they are actually selling a physical bike!!
Reactions: matthewslack
matthewslack
2,594
1,671
Yeah £4k!!
Sorry pity party!
Good luck.
Giraffe
9
9
I have a horrible feeling this will have exactly same problem as the expensive bike you couldn't ride.
This appears to be a bike for people who just want fairly light assistance. The system is torque sensing and fairly low torque. Like the other lightweight systems in its class like Fazua.
Based on what you've posted I suspect you want 1/ lots of assistance and 2/ a legal throttle. If possible the bike should be lightweight but most lightweight bikes are light assistance which is no use to you. So you (probably) need to compromise on weight to get heavy duty assistance and legal throttle.
But the main thing is try before you buy.
Peter.Bridge
1,864
828
Trek fx3 low step (this one is medium -not sure what size you need) 11.5kg
Add akm100 hub motor (2.1kg) and say 36v 15 amp battery (bag battery 2.4 kg, or rack battery 3 -3.5 kg) + KT controller, LCD, PAS and throttle
Probably around 18kg in total, maybe a little less if you use a bag battery)
8,841
People tend to forget that adding a battery and drive system to a bike adds weight, not only that the bike design itself will also in most cases be more sturdier then a push bike.
Lightweight bikes are available but these tend to be sportu road type bikes with minimal battery size and small hubs for the fitter rider who usually only wants light assisstance now and then.
Reactions: sjpt and Woosh
Katymac
177
46
57
Norfolk
"Lightweight bikes are available but these tend to be sportu road type bikes with minimal battery size and small hubs for the fitter rider who usually only wants light assisstance now and then"
this is a missed market, the disabled rider, the older rider, the smaller rider even the pregnant rider need light weight bike - it's about wasting energy for the rider with a chronic illness
My daughter riders everywhere, but when she was pregnant, when she is travelling home from a performance/dance show she just wants to whizz home (not speed just ease/lack of effort)
3,410
Your needs are more niche than hers. In addition: more even weight distribution and larger wheels than your Cruza, and it must be step through. I can't find a reasonably priced lightweight step through bike or bike frame (custom built titanium would be too expensive) which can have a middle-ish mounted large capacity battery easily fitted, for an overall lightweight rear/front hub cadence sensored conversion, which would be lighter tham mid-drive.
Peter.Bridge
1,864
828
More powerful bikes have heavier motors. Longer range bikes have heavier batteries. Beyond a certain point (10-11 kg ) reducing the weight of the non e-bike specific components is chasing diminishing returns. The lightest conversion kit I've fitted had a 1.6kg AKM 75 motor and a 1.8 kg 36v 10Ah bag battery but isn't massively powerful and doesn't have a huge range if you use all the power.
That's the beauty of building a bespoke bike, you can choose what's important to you and fit a conversion kit to suit, but if you want lots of power and lots of range using that power it's not going to be light
