Disabled cyclist; with one bad choice behind her, needs help with a new bike
Katymac
177
46
57
Norfolk
I know what I don't want (I already have that)
I need a low step through, with shedloads of power to take me not very fast, everywhere, even up hills
I needs to be light, with big wheels, suspension, very sit up and beg
In fact a complete cross between the 2 bikes I have
The crusa is too heavy and all the weight is at the back so it's unstable when I walk with it or load it on the train
The fazua is too big for me I can't get my leg over the bar and my legs aren't strong enough to register on the torque/motor
3,397
A trike would be heavy as * so it won't increase my mobility & now I can't even open the sodding car door, so driving will only work if there is someone there to let me out ffs
This is worrying - are you sure you're still strong enough to control a bike? If you're no longer safe cycling, perhaps it's time to start a thread asking which mobility scooters are easiest to hotrod? Increasingly popular with able-bodied people. At times I'm tempted to hotrod one myself, usually when swiftly overtaken walking on the pavement by one whizzing past at who knows what speed, and annoyingly they never ring a bell or beep. Looks fun.
4,036
"Lightweight bikes are available but these tend to be sportu road type bikes with minimal battery size and small hubs for the fitter rider who usually only wants light assisstance now and then"
this is a missed market, the disabled rider, the older rider, the smaller rider even the pregnant rider need light weight bike - it's about wasting energy for the rider with a chronic illness
My daughter riders everywhere, but when she was pregnant, when she is travelling home from a performance/dance show she just wants to whizz home (not speed just ease/lack of effort)
The two requirements of high power and lightweight are conflicting characteristics. It's not that somebody's missing a market, it's that physics prevents it.
matthewslack
2,548
1,651
A bit like building a house. You can have a good house, a cheap house and a quick house. But only two of those three.
8,792
This thread has been going for over a year now plus the previous thread of the bike her brother built for her with the specs to suit himself.
Cat is looking for the nirvana of ebikes wihich doesn't exsist for a rider with debilitaing health issues or a movement disability. Typically one has to accept there will be constraints and not think of being in one's prime when these health issues may not have exsisted or been so prominent.
A trike or legal twist and go seem the probable route
It has all been said . One can't have power , long range in a light weight bike.
The focus does seem to be a tunnel vision view all etched on an unsuitable style of bike system of a torque sensing mid drive bike . Which all in all has all been drawn out and discussed now many times , to which the answer from most is that this is just the wrong bike system for said such use with the underlying health /mobility issues.
17,344
it's can be done.
You start with a 10kg full sus for comfort. That's the key to build a good bike because the components are very good to start with.
You add a tongsheng 85TS kit with a bag battery for 40 mile or 60 miles or HL downtube battery for 80 miles range. Total weight 14kgs with 36V 10Ah. Mine is like that. I can ride it on any trail and have a throttle if needed.
4,036
it's can be done.
I thought we already established that a a system with torque multiplication was unsuitable for her. Why do we keep going round and round in circles, with people keep recommending what's suitable for themselves instead of for Katy? She wants lightweight, power without much pedal effort and enough range.
Reactions: Nealh
17,344
We go in circles because you are looking at factory made bikes which are always less flexible than kits.
I think she only has to dial up assist level to 3, 4 and 5 instead of 2 o3 that I am on most of the time. She can always fall back on the throttle if 4 or 5 are insufficient.
The 85TS has 'instant start' like Mechaniker has on his bike. The main difficulty with fitting the 85TS kit to a high performance bike is most of them have tubeless tyres. The 85TS comes with normal double wall rim, not tubeless.
8,792
Problem is with any twist and go use is !!! The risk of plod confiscating said bike and a conviction for motoring offences.
Tbh the only solution to be compliant is one with full twist and go that is lawfully legal and complies with the 250wLPM certification.
8,792
Most of us are regular riders with maybe minor issues but once we start talking about major fatique issues with lack of leg power /muscle /stamina then I can't believe TS systems are being promoted.
3,397
...causing Rapid Fatsos to conclude incorrectly all legal bikes are inadequate and only Sur-Rons or escooters will do.
63536
3,397
it's can be done.
The lightest conversion kit I've fitted had a 1.6kg AKM 75 motor and a 1.8 kg 36v 10Ah bag battery but isn't massively powerful and doesn't have a huge range if you use all the power.
Is there a large wheeled (larger wheeled than @Katymac's Cruza) <10kg step through which can be fitted with a 20Ah mid-ish mounted battery and 22A controller, for a <17kg cadence sensored bike with legalised throttle? Or would that be too heavy? 22A X 48V = 1056W legal throttle would make nearly all hilly roads seem flattish.
My cadence sensored bike enables me to ascend most roaded hills at 25kph, largely effortlessly, and this is with just a legal 662W (on 20" wheels [18.4A, because I forgot to increase level to 20A and 720W, which would have been even easier to pedal]).
17,344
I have 26inch wheels, 85TS max torque is 45nm. The controller is set for 17A. I weigh 75kgs. Most of the time I am on assist level 2, occasionally on 3. I get up Pier Hill in Southend-On-Sea ok. Peter has the lighter and smaller 75 motor. You don't need more power unless you weigh 100kgs or live in Cornwall.
Reactions: Peter.Bridge
3,397
Big fat French people tend to grow stronger leg muscle than those of the the small and disabled, because the fat needs to be heaved about. Leg muscles grow stronger gradually as fat accumulates with heavy consumption of cheesy baguettes and wine.
Bike manufacturers/integrators must like the lower continuous discharge rate required by torque sensored bikes, because of course there's less stress on batteries and other components, but I suspect this push towards TS is leaving oodles of people thinking legal bikes are all crap and unsufficient for their use cases, thus leading to the roads filled with Rapid Fatsos on illegal Sur-rons and escooters situation illustrated above. It isn't easy imagining being weak, and one imaginngs are almost always wrong.
17,344
I like the 85TS kit because it helps keeping my muscles without sweating. It's also very nice to ride with.
3,397
I would but Katymac wants something chic.
After more than a year seeking a solution, I imagine @Katymac would even accept a bike made of lightweight stale baguettes reinforced by encrusted cheese and particularly fibrous herbs, if it functioned as needed.
Katymac
177
46
57
Norfolk
"After more than a year seeking a solution, I imagine @Katymac would even accept a bike made of lightweight stale baguettes reinforced by encrusted cheese and particularly fibrous herbs, if it functioned as needed."
Well yes, but I'm dairy free too (& it's closer to 3 years in all)
Ok today has been enlightening
Weight in the middle.changes parking and maneuvering so so much
Plus a bike shop that alters the seat without sighing and voluntarily alters the handle bars
I tried 4 and oddly the more powerful motors were less comfy - the handlebars adjustment made more difference than the motor size
This is interesting https://www.kalkhoff-bikes.com/en_gb/image-3-advance?color_combo=64686&ipmc_frame_shape=52206
But I'm back on Wednesday to try 3 more; I couldnhave tried them today but the motor on a moustache (sp?) cut out and I had to wheel it home using my spare energy
And tbh I think it's everything I said I didn't want - which makes me feel very stupid
The car door thing is an angle issue i think - we have a ford tourneo connect and the doors are heavy, my daughters car is easier
matthewslack
2,548
1,651
It would be useful to know if, in the course of your so far endless quest, you have tried the higher spec mid-drive motors, and whether, purely from an assistance point of view whilst riding, ignoring weight and balance when handling/lifting, they met your needs.
Katymac
177
46
57
Norfolk
I'm not sure
I tried a trek and a cube the other day which weren't for me but I forgot to write down what they were
I tried several kalkhoff that had bigger motors but I didn't like them (although after he changed the handle bars I could ride the bigger one more easily but it wasn't great)
He didn't have a medium of the one I like (only a small) and he thinks I need medium
I'm going back to try a whisper and a moustache and a different karkhoff
That doesn't answer your question I'm sorry
