recently I had some problems with a bit of moisture in the motor, so I dried the motor out, sealed everything I could with silicone, and put plenty of Vaseline in the joints of the axles to stop water getting in through the cogs and the wire end. I spent about 15 minutes making sure that I got a little wad in at each end.
I went about 5 m in the garden and started hearing the thudding sound again-so I figured the petroleum jelly must have gotten into the circuitry.
but it gets worse-I look down and the back wheel had fallen out from the bolts because the whole area was in contact with Vaseline, and the cable got twisted about three times over itself.
the wheel was done very tightly but the lubricant made it slip very easily, and now I have the prospect of trying to get the Vaseline out and having to test all the wires. damn.
