Doesn't the discharge rate multiply depending on how many cell's in parallel?This discharge rating is a negative for me but otherwise OK
Right, I'd like to see the voltage drop for a typical 36V 10Ah battery under a 10A current draw.the Ri is lower so the voltage holds up better under high discharge.
Lets see if I understand this correctly 1 x 3000mah cell rated at 2c = 6ah?No, its still 2C, however, the current delivery will improve when more cells are paralleled up, in this case 2 in parallel will deliver 11.6 Amp, 3 = 17.4Amp etc at max discharge rate....however, its much better for the life of the cell if it can support higher discharge rates IE 20~30C = less stress on the cell and the Ri is lower so the voltage holds up better under high discharge.
Oh I know. Sorry I wasn't very clear, I actually meant that I'd like to see the voltage drop for this particular type (and brand) of cellCan't help there Dan but it's well known, here's a link to an old page on batt uni, best I can do at this time of night plus I can't be bothered...have a search around the many threads on ES it's been discussed many times there...
Internal battery resistance
This sounds about rightLets see if I understand this correctly 1 x 3000mah cell rated at 2c = 6ah?
Four of the same cells in paralell would be 4 x 3000 = 12000mah so if still at 2c equate's to 24ah? The capacity multiply's but the c rating doesn't. Is that correct.
How many amps is a 36v 250w ebike going to draw at most?This sounds about right
It depends on your battery, controller, and motor. For example, my motor could theoretically draw more amps than 10A continuous, but in practice the controller has a current limiter, so the observed peak (using Cycle Analyst) is about 10A (actually the CA registers 15A because of the spike created by the condenser when connecting the battery).How many amps is a 36v 250w ebike going to draw at most?
Actually that's not correctThis sounds about right
With hub motors in mind......How many amps is a 36v 250w ebike going to draw at most?
I know it doesn't make it a 24ah battery but the 2c rating means its max discharge rate is 24ah. Is that right?Actually that's not correct
A 2C 3Ah cell is still a 3Ah cell It means the cell can deliver 3amps for 1 hour or a maximum of 6amps for half an hour.
Four of the cells in parallel makes a 12Ah battery with a 2C rating. It does not make a 24 Ah battery.
Isn't that exactly what he said ?Four of the 3Ah cells in parallel makes a 12Ah battery with a 2C rating. It does not make a 24 Ah battery.
Ah is the capacity not the discharge rate or current...so the discharge current is 24 ampsI know it doesn't make it a 24ah battery but the 2c rating means its max discharge rate is 24ah. Is that right?
Oh sorry, I mis-read A vs Ah !Ah is the capacity not the discharge rate or current...so the discharge current is 24 amps
