E-bike won’t go over 20mph
Gaknight
7
Hi all and thanks in advance of your help. I’ve had my Carrera subway e-bike for 3 years now and I hadn’t used it for about a year as it had the cutting out problem always seemed to happen on hills lol. Halfords were useless fobbed off with pathetic excuses for a known fault. Well I got it out to see if I could get it going good again or needed a new e-bike. So got the battery charged up and tried again. It took some fettering about to release the brakes but all done and to my surprise it powered up and away I went all good. Except when I get to a nice downhill and want to see what speed I can get the bike feels like the brakes are restricting my speed to 20 mph. Before the bikes lay up I regularly hit 40 mph on the steep hills. Any help solving this problem would be greatly appreciated. Thanks
6,319
you need to remove the brake pads reset the pistons in the bake reinstall the pads and center them so there not rubbing.
prob best to get a cheap bike stand to do this.
2,077
You can check whether the brakes are binding straight away by lifting the bike and spinning the wheels by hand. If the back wheel doesn't spin, remove the brake caliper from the disc (2 screws) and try again. If the wheel still doesn't spin, the clutch is stuck, so whack the wheel in the forward direction to free it.
Gaknight
7
Both wheels turn free now but rear wheel doesn’t turn as free as front Also when I turn the rear wheel it feels like friction in the motor stops it turning as freely as the front.
Gaknight
7
I’ve got new brake pads and will do this when my bike stand gets delivered.
6,319
i doubt the brakes would slow you down that much tho
6,319
bearings could be shot/ ceased
6,319
will have to get inside off it and take a look first.
Reactions: Gaknight
Saracen
342
21
It is ILLEGAL in the UK to go over 20 I assume either you are NOT UK based or don't care about other people or the law
GOOD for Halfords in not helping you illegally to de restrict a bike
  • Disagree
Reactions: joelectric
Peter.Bridge
670
302
No it's not. The motor should not assist over 15.5 mph (or 17mph if you include the 10% leeway) but you can cycle as fast as you like non assisted
Gaknight
7
Only in a twenty mph speed limit zone. My e-bike stops assisting me at 15.5 mph then I am on my own steam.
2,675
Due to odd quirks in the way speed limits apply, probably not illegal to exceed 20mph even in a 20mph zone ;assuming the bike is in every way legal as a pedelec.
Saracen
342
21
UK law NO ebike goes over
15.5mph
Other than that you have had the only good advice above
An ebike can go as fast as you can pedal, as long as you do so safely. In terms of electric assistance, this can't be provided above 15.5mph on UK roads if you want the electric bike to be subject to normal bicycle rules.
  • Disagree
6,319
give me 20k ill make it 200bhp electric :p
