For Sale Ebco Eagle LSL 50
millyboy
7
Hereford
For sale an ebco eagle lsl 50 electric bike.
Brought for my wife in 2012 the bike has done less than 100 miles, however due to lack of use the battery has died, so it requires a new one or possibly just a recelling of the original battery pack. The bike was £1600 when purchased, I would accept £250 for it but a buyer would have to collect. The spec is:
FRAME & FORK:
Lifestyle low step frame built in T6 high grade aluminium and finished in arctic white with internal cabling and custom headstock suspension.
WHEEL SET:
20″ aluminum cast wheels with Schwalbe Big Apple 20 x 2.15 tyres with kevlar puncture resistant guard.
ELECTRIC DRIVE SYSTEM:
TRANZX PST 250 watt 36 volt brushless high torque electric front hub motor with integrated controller matched to an RPM sensor and TMM4 sensor with a DP05 LED display screen with 3 power support modes and a turbo button.
BATTERY:
Lithium-polymer 36V 10AH battery which locks securely and is removable for charging (charger supplied).
Range: Up to 50 miles (average range in eco mode)
Up to 80 Kilometers
Recharge Time: 5-6 hours from flat. (less from part charged)
GEAR SYSTEM:
Shimano Alivio 8 speed derailleur with Revoshift shifter
BRAKING SYSTEM:
Tektro novela mechanical disc brakes front and rear
COMFORT PACK:
Ergonomic handle bars and grips together with a fully adjustable (for height & reach) stem and plush comfort saddle with easy adjust seat post give all EBCO bikes a confident and comfortable riding position. Mudguards and chain guards give excellent all weather protection.
SAFETY PACK:
Selected EBCO bikes are equipped with a fully integrated lighting and reflector system. All EBCO bikes feature a high performance braking system with safety motor cut off brake lever, smooth rolling tyres with reflective side walls and comply with EN15194 EU Standard.
Frame Set
Frame: Lowstep – High grade aluminium 6061-T6 frame
Fork: Custom design aluminium fork with headstock suspension – 35mm travel
Headset: Semi integrated
Colour: Arctic White
Size: Single size frame (ideally suited for inside leg measurement of 26-35in)
Electric Drive System:
Electric Motor: TranzX PST 36volt 250 watt brushless high torque front hub motor
Sensor: Intelligent TMM4 torque sensor matched to an RPM sensor
Controller: Precise integrated motor controller (in front motor hub)
Display: TranzX PST DP05 display indicating battery charge status and 3 levels of power support and turbo button
Battery:
Battery: Latest technology 36V 10AH Lithium-polymer battery (slides into rear carrier)
Range: 44-50 miles depending on level of assistance, load and terrain (figures are based on average use in eco mode)
Charger: 36V TranzX charger with UK plug
Recharge Time: 5-6 hours from flat (less from part charged)
Drive System:
Gears: Shimano Alivio 8 speed derailleur
Gear Shifter: Shimano Revoshift 8 speed shifter
Chain: KMC Z72 8 speed chain
Chain Set: Aluminium forged 52 tooth 170mm crank
Freewheel/Cassette: 8 speed Shimano cassette 11 – 32 indexed
Pedals: VP F60 fold flat pedals
Bottom Bracket: Cartridge sealed bearings 118mm axle
Brakes:
Brakes: Tektro Novela mechanical disc brakes front and rear 160mm rotors
Brake Levers: TranzX PST brake levers with safety motor cut off protection
Wheel Set:
Rims: TranzX PST 20″ one piece aluminium cast wheel
Hubs: As above
Spokes: As above
Tyres: Schwalbe Big Apple 20 x 2.15 with kevlar puncture resistant guard
Inner Tubes: 20″ inner tube with car type valve
Rider Cockpit:
Handlebars: Ergonomic comfort design
Grips: Ergonomic design kraton rubber grips
Stem: Aluminium “tool free” adjustable stem (height and angle)
Seat Post: SP 61 aluminium 33.9mm diameter 380mm long
Seat Clamp: SC 61 aluminium quick release 38.1mm diameter
Saddle: EBCO comfort suspension gel saddle
Fitted Accessories:
Carrier: Integrated custom rear carrier with 25kg load capacity
Lighting Kit: Integrated Basta front and rear lighting system
Reflectors: Reflectors integrated with lighting system and reflective side wall tyres
Mud Guards: Front and rear custom mud guards
Chain Guard: Helsing Esen half chain guard
Stand: Adjustable side kick stand
Bell: Aluminium mini bell
Weights (approx):
Weight of battery: 3.9kg
Weight of bike inc battery: 26.8kg
Any questions please ask.
millyboy
7
Hereford
Hi sorry I sold it locally.
Guess I should have marked as sold but had forgotten about posting it on here!
