Ebrompton gear ratios
shemozzle999
2,826
686
I have been playing around with the gearing on my 2 Brompton M6R bikes, they both came with the standard SRAM hub with 13/15 sprockets and 50T chain wheels.
I found I could not keep my cadence up to match the extra assistance provided by the ebike conversions.
I upgraded one bike to the new BWR hub which came with a 13/16 sprocket set.
It slowed the cadence down in top gear but found the steps too great in the lower gears.
I replaced the 13T sprocket with a 12T which improved matters greatly.
On the second bike I decided to change from the 50T chain wheel to a 54T this also had the desired effect of lowering the cadence and maintained the closer step changes between gears although slightly increasing my lowest gear ratio.
I was helped by a link on another forum to a particularly good Brompton gear calculator which assisted me with my decisions.
Link:
Hub Gear Calculator
It can be used for any bike setup if you remove the Brompton specific tick mark.
I like the way you can change the output results to mph and then set a cadence figure.
jerrysimon
3,292
112
Cambridge, UK
I find anything less than a 54T main and 12T rear i.e. 74" gear on my two speed Brompton too low at full assist speed.
That is the highest you can take a two speed Brompton up to with OEM parts.
With my after fit S2C or my preferred SRAM Automatix hubs I can get this up to 76".
I rarely exceed 20mph on my Brompton and most of the time am happy to cruise along at 16-17mph. If I want faster rides I take one of my 20" wheeled bikes out.
Regards
Jerry
shemozzle999
2,826
686
Hi Jerry,
That is what I have found too.
It needs the increase in gear ratio for full assisted use.
I do not find the description of gear inches conveys much but if you change the units in the calculator to mph or kph it opens up a box for you to enter your preferred cadence and gives the output in the units chosen.
The calculator can be used for any bike if you uncheck the Brompton-compatible data only tick box.
p.s. Did you get the hotmail?
