Ezee Derestrict Switch
C
Cyclezee
I feel sure someone has done this already and would like to hear how.
I am currently running my Ezee Forza in derestricted mode, but want to fit a simple on/off handle bar mounted switch to enable me change easily between restricted and derestricted mode.
I lack the discipline to restrain from using full throttle when ever possible and think a simple switch would help cure this.
What switch should I use?
An alternative might be some sort of mechanical means of restricting the amount throttle rotation?
Any suggestions would be welcome.
J:) hn
JamesC
435
Peterborough, UK
John
I used this rocker switch from DirtBikeStore. Page down on this link to Handlebar Lighting Rocker Switch.
Used an indelible marker to erase everything except Off (=Offroad !).
James
C
Cyclezee
Thanks James,
That is exactly the sort of switch I was thinking of, I guess it is waterproof too .
J:) hn
JamesC
435
Peterborough, UK
Thanks James,
J:) hn
It is not waterproof as such, but seems to be sufficiently shielded to do the job.
James
C
Cyclezee
Thanks for the tip Tony. I frequently use you site as source of invaluable information.
In my job I throw away about 20 pairs of used Nitrile surgical gloves a day, great if you have an allergy to latex, but for strength and durability I would recommend latex for every purpose;)
J:) hn
30,849
I agree latex is better John, but the vinyl gloves are so cheap and readily available I used those.
Phil [OnBike]
54
That switch is great - thanks for sharing James!
I've been looking for something like that for a while now to pop on my Forza.
